GE 30 in. Profile JP989 Electric Cooktop Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the glass cooktop. Can anyone
I need to replace the glass cooktop. Can anyone explain how to remove the damaged one? Thanks for all your help.
Anonymous
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
34
Questions
Helped
4734
Points
103
You have to call the company who it was manifactured out of sorry
I need to replace the glass top on a jenn air JES8850BCS slide in range. How do I do it? Can it be done leaving the range in place or does it need to slide out for the replacement? Thanks.
It looks as if you need to remove the whole cook top to replace the glass top, incidently that is a 400 dollar item, so you have to take care. See: http://www.partselect.com/PartDetail.aspx?Inventory=2341162&SourceCode=5&ModelNum=jed8430#RepairStory
2helpful
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
6helpful
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Jenn-Aire Cooktop Glass
You can order the replacement glass for about $225 from companies like Repairclinic.com or appliancepartspros.com
Part Number: AP4095442 made by WHIRLPOOL, black
Part Number: AP4096135 made by WHIRLPOOL, white
I have a KitchenAid KESS907SSS 30" Slide-In Electric Range with a broken glass cooktop. I have the replacement cooktop and want to do the replacement myself as I live on a remote island. It looks like...
Problem solved. Followed the instructions given and successfully changed the cooktop.
It turned out that the front control panel needed removal in order to access the screws behind it. After that it was clear sailing.
Thanks for your help with this.
2answers
Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Nov 23, 2007 • Cooktops
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
