Question about JVC AV-36950 TV
My tv will not turn on and the on timer light is
I have a jvc tv.. its a av-36950... The tv was on and then its just turned off and the (on timer) light flashes and the tv will not turn on.. I have pused all the buttons and unplugged the tv..
Posted by thabsieger on
Anonymous
    New Friend:
  • 8 Answers
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Posted on May 25, 2010
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
JVC AV-36950 that turn off after being on 30 min
Check for any loose solder contacts at its main power regulator [SMPS] stage. Re-solder all the suspected solder terminals. If you wish to get some details; visit the site linked here. Pull up older posts.
Oct 12, 2017 | JVC AV-36950 TV
No picture have sound and red light is steady on
This maybe due to a blown damper,capacitor,or internal fuse.You may have to take it to a repair shop.
May 17, 2010 | JVC AV-36950 TV
When I push the power button, the red light flashes and no picture shows up. it just clicks right back off? do you know what causes this?
Go to the following blog address to find detailed instructions on how to fix your TV for around 2 dollars yourself! It really works. I fixed mine this weekend.
Good Luck...Kim
Jan 09, 2010 | JVC AV-36950 TV
Will not turn on
Go to the following blog site for detailed instructions on how to fix the TV yourself for around 2 dollars! I fixed mine myself this weekend and I know nothing about TV's. Thanks to this site, I saved hundreds of dollars.
Good Luck...............Kim
Oct 13, 2009 | JVC AV-36950 TV
JVC AV-36950 TV won't turn on
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
Jan 20, 2009 | JVC AV-36950 TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
Dec 09, 2008 | JVC AV-36950 TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
Model AV-36950 won't turn on
Hi there, yes this is common. I dont know how much technical expirence you have, but be very careful there are many circuits that have high voltage on them, even when off, and these voltages can be lethal, especially any thing that is connected directly to the A.C. line [such as the primary of the power supply]. most of the rest of the set is isolated from the A.C. line. so be careful. now for the tecnical part, most common is a failure of the vertical circuit, the shorted IC will cause the set not to come on in order to protect the power supply. after you replace the IC and any resistors and diodes that may have failed as a result of the bad IC, change any caps related to the vertical circuit, they will be 100, 220, or 47 mfd @ 35 volts or so. lastly check the zener diode that is connected across the output of the IC for leakage or shorts. It is also possible for a filter cap. in one of the low voltage supplies to be open [it may be noticed as it will be pregnant.]to cause a no operation condition. so good luck and think safety.
Jun 13, 2008 | JVC AV-36950 TV
JVC AV-36950 TV Logo
812 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
