Question about Hannspree HW191D LCD Monitor
Hanns G HW191D flickering. Monitor works fine but flickers.
Posted by jonnyb814 on
Andrew Wilson
    New Friend:
  • 54 Answers
Go into your monitor properties and change the refresh rate to a lower setting.
Posted on Jan 14, 2010
Monitor wont work
Try a different power cable. If it uses a 'brick' type power supply, try a different one. If that doe not fix it, the monitor is bad (which is why it was given to you). Monitors are cheap, get a new one. Good Luck.
Dec 14, 2017 | Hanns.G Computers & Internet
I can't get the audio to work. Lost manual and can't find the audio switch. Hanns-g hw191d
just download the manual here.. http://office.manualsonline.com/manuals/mfg/hannspree/hw191d.html hope this helps... thanks
please vote by the way.
May 18, 2011 | Hannspree HW191D LCD Monitor
Im having issues with the hanns-g hg281d. my screen is always faintly flickering, especially when the screen is on darker colors
i was having same issue.i would turn off monitor for 10 secs. then turn on .and it would not happen for a while .i went to i cable and it now rearly ever happens.
i use this as a external monitor for my laptop for 6 mons.now.
Jan 04, 2011 | Hannspree HW191D LCD Monitor
Speakers on Hanns G HW191D monitor don't seem to work properly. This is new and I cannot get any volume from the speakers (well just about can hear it). Should I be doing something to make them work...
monitor speakers are usually not the best and in most cases not amplified. Try using the same wire to another pair of known good speakers. If they work fine then you'll know for sure.
Nov 05, 2009 | Hannspree HW191D LCD Monitor
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
My Hanns-G hw191d monitor quit coming on. The green light at the side is on, indicating that it is receiving signal from the computer, but nothing displays on the screen. Is there a fix, or should I just...
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
Jul 06, 2009 | Hannspree HW191D LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hannspree HW191D LCD Monitor Logo
1,023 people viewed this question
Top Hannspree Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Karl Luedemann
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
