Epic View 550 Treadmill Logo
Anonymous Posted on Jan 14, 2010
Epic550 treadmill shutdown unexpectedly and display is blank.
I own a Epic550 treadmill. It shutdown unexpectedly after 6 minutes and the display screen went blank. The magnetic switch was in place. I checked the power plug for electricity and checked the thermal fuse. Both these items were fine. The speed was 3.6mile/hr, incline just set to 4% grade and the TV and fan were turned on. Do you have any suggestions?
mlkary
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jan 16, 2010
mlkary
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
14737
Points
61
Check the upright wiring harness on the right side. If the harness was routed incorrectly or care was not take during installation, the harness is pinched/cut/damaged when the right upright is bolted on. This is the main issue I encounter on this style treadmill when it will not work after assembly. Will require a new upright harness if damaged. If it is under warranty, call and have them replace it. It is covered
Testimonial: "The wiring harness was indeed pinched and the control fuse was blown. A little solder and a new fuse fixed the problem. Thank-you for the insight."
  • Magic Way Sep 05, 2010
    Hello, Ive lost my manual and have read that there is a thermal fuse, can you please tell me where it is located?
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
2answers
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
I got an E1 error code the other day. Treadmill started and ran for a few seconds and just shutdown. What could that be? I have a Bodycraft TR 1160 that's about 6 years old.
This conditions will be cause an abrupt
shutdown of the bel and the motor controll detect an sharp increase a drive current and inmediate stop driving belt.Some situation will be damming the belt and cause this error code .Without abuse will be a situation for cause a extreme care and analysis.
2answers
Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
Apparently Sears will be replacing our treadmill at some point!
Mike
3helpful
The display turn off after few minutes (blank screen, no message). When it does that, the power led stay green. When I turn it off and on, the display work again for a few minutes and the same problem...
jackperson, Might be internal problem with the units power supply (ac line in to DC conversion) having shutdown issues. You will need to do some reading in my fixya profile for a while and then you will know what to look for inside unit. If not into electronic repair stuff, skip the reading and trade-in unit for new, if current unit is 4, 5, 6 years old. 12fixlouie
Unexpected shutdown with new battery ...only
This is a duplicate submission -- I will be answering the other copy. Thanks.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
