RCA TH1101 MP3 Player Logo
Question about RCA TH1101 MP3 Player
Model M4304 mp3 video player plays music but
Model M4304 mp3 video player plays music just fine but after a min. or two the screen turns off by itself and when i press the pause button the screen just disappear, but the music is still playing
Posted by hdanny55 on
Anonymous
  • 1,871 Answers
Update firmware ! if didn't work , then take it to the service ! rate please ! best regards .
Posted on Jan 14, 2010
Rca mp3 player is frozen and can't play music
plug the rca into the power oultet and hold the power and that might un freez it and it will work
I hava a RCA OPAL MP4 Player Model M4304 And I Do Not Know How To Put Videos On It. Please Help.
i had te sameproblem, when conecting to the pc, if is recognized open the opal program, it should have lised among all the folders like: music, videos, etc one that says RCA EASY RIP thais th ONLY program that will convert the files to the correct format to play the videos. click on the set up, d followthe directions, easy to use. aftertht it will transfe the videos that you pick and they will play correctly, again ONLY this pogram work.
2answers
The rca easy rip says player isnt conected???
I had the same problem. I was able to get my new music on mine through my windows media player, then able to sync it on to my RCA MP3. I am not very good with technology but it worked for me. I guess the media player is my default program.
I don't know how to upload music into my M4304 RCA MP3
There should have been a file on the player that you can access through Windows Explorer (My Computer, click on the dirve that is your player) that should be named: RCAeasyRip_setup.exe
If you do not have this file, it can be downloaded from the RCA site here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2253
Run this file to install the RCA easyRip softwar that allows you to transfer all media. You HAVE to use this application to transfer videos because it does the conversion to a compatible format (if Windows Media Player can play it, easyRip should be able to convert it). Any questions you have about using easyRip can be accessed by the module on the dock that has a '?' on the icon for it (Look up the Player Loader module for how to transfer).
Other media you can just drag and drop to the device if you don't care about video (again, just find the drive letter that is your player in My Computer and just drag and drop music and photos onto that drive)
Lastly, you can use Windows Media Player to sync any music and photo files.
2helpful
2answers
How do i load and make videos play on my rca m4304
http://www.rcaaudiovideo.com/product.aspx?product=420
follow the download link on the right hand side of the page and download the firmware and easyRip software upgrade
I do not that I am not having much success with Windows 7 though
M4304 mp3 player building database then cuts off
I'm not sure if this is the correct thing to do, but it worked for mine. First, go to the RCA website and follow the instructions to update the firmware on your player. Second, disconnect the player from your computer when the install is complete. Then, turn your player on. Once the screen comes up that allows you to go through your folders and settings, turn it back off and re-connect it to your computer and upload your music. I tried to upload 3 GB of music at once and had to redo this process. So now I just upload a little music at a time.
Also, I found it is better to load your player with music through Windows Media Player than to use the software that comes with the player.
Here is the link to update the firmware:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/5635
It won't let me play my music!
no worries. there may be a read error. if it still connects to your computer fine download all of the files, movies, mp3, mp4 etc back onto your computer. once you have done this go into the file holding all of the mp3's and set the file to show details and look for a mp3 that is the incorrect file size... in general comparison to the other files. also if the device came with software look around for a restore factory settings button or wizard, and once the device is completely clear restart it and reload the files back onto it, remove the device (safely) then switch it off and back on and then try it out again. hope things work out bro.
Top RCA Audio Players & Recorders Experts
Steve
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
