Teac CD-Rewritable W58E CD-RW Burner Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
Adimurugan.V
Level 2:
  • Expert 119 Answers
  • Posted on Jan 14, 2010
Adimurugan.V
Expert
Level 2:
Answers
119
Questions
0
Helped
61293
Points
266
Your drive is CD-W58E. It is not a combo DVD driver. It is only a CDRW drive.See you drive specification at http://www.teac.co.jp/dspd/product/optical/cd-w58e.html
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
23938
Points
309
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
2helpful
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer...
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
What type of disc does a sony crx830e support
This is a combo drive
It will support
1. CD reading & burning (Blank CDR and CDRW)
2. DVD reading only.
We cannot use a combo drive to burn DVD.
1helpful
My lite-on combo sohc -4832k driver is supposed to be a DVD writer as well but every thim i try to put a blank dvd r into the drive to burn a movie i made it just ejects it and says to put in a blank on....
make sure the drive is getting enough power
one bad/faulty lead can cause a computer lots of problems
make sure all leads that connect to the dvd drive are seated properly including the electrical lead or just replace them there probably old/faulty
hope this helps
1helpful
2answers
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Blank DVD
What are you using to burn cds?
Try using the free burning version at http://www.deepburner.com
Blank dvd media is not reconized
You have to pre-select type of media in your burning program (CD or DVD) before adding files and commencing burning procedure.
ATAPI DVD+RW Burning Problem
DVD / CD-RW is usually a a combo drive
DVD PLAYER with CD BURNER
DVD-RW is a dvd rewritable drive
2answers
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
1helpful
Cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
1.Please cheack weather the DVD meadia is DVD R/W combo drive, 2.Then only the DVD media will be Burn or write tO the Blank dvd media & then check weather the blank cd is a dvd r/w cd.
Top Teac Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
