Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
Spherex XBOX surround system has started shutting itself down after around 30 seconds. Prior to this, the display starts "pulsing". Is this an inexpensive repair, or should I ditch the system and buy something new?
Posted by Brian Sinclair on
VBtoons
  • 28 Answers
Your problem could be with your IR reciever, toggle it and see if it the lights flicker. Possibly wedge it so it stays on. As for the pulsating, are you connected via analog?
Posted on Feb 26, 2010
Ian Robertson
  • 185 Answers
Hi there bud ....What i suggest is , if you still have a warranty , send it in and see what they can do....Otherwise Compare the price of a repair and a price of a new one...and there you go :)
Happy new year
Posted on Jan 13, 2010
Speakers have hiss and crackle but no sound coming through optical feed on spherex xbox 5.1 surround system
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 27, 2011 | Spherex Xbox 5.1 Surround Sound System...
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
Is the spherex xbox 5.1 surround sound system compatable with the xbox 360, if so how would I set it up because It's not working the way I'm doing it.
yes my bf has if u have a newer tv u just plug in to the digital audio output or u can plug it right into ur xbox ull need the adapter that comes with it
Mar 05, 2009 | Spherex Xbox 5.1 Surround Sound System...
Spherex Xbox 5.1 Surround suound..USB does not work
If the xbox is not able to recognise the usb, it is most likely that the product is not compatible with the xbox i would look for an adapter which would take the usb connection to the xbox's analog connection, or if your speakers have a stero 2.5 connection then you can easily find an adapter to connect to the xbox's analog connection in the back, the analog connection is the red and white ports at the back!.
Feb 11, 2009 | Spherex Xbox 5.1 Surround Sound System...
My xbox 5.1 SPHEREX SURROUND SOUND SYSTEM DOES NOT WORK NO POWER
my bfs did this same thing he went to radio shack found the fuses replaced them and boom works great its been workin over a yr in half now no problems
Jan 10, 2009 | Spherex Xbox 5.1 Surround Sound System...
DVDs are ridiculously loud
Pull down on your right analog stick to lower sound on XBMC.
Nov 30, 2008 | Spherex Xbox 5.1 Surround Sound System...
Freezes, no sound, won't turn on!
Hi Joeker, I believe you have a problem with heat. Also to get this problem solved, you need to open the main box and clean it up real good. I use a paint brush to dust off the circuit boards. Clean all the dust and lint out of the box. Put it allback together and make sure the main box has plenty of ventilation. do not set it on carpet, this will restrict it's natural circulation of air. I truly hope this helps you.
Oct 09, 2007 | Spherex Xbox 5.1 Surround Sound System...
Rear speaker buzz!!!!!!!!!!!!!!!
i had the exact same problem which eventually spread to all speakers i took it to local repair guy, he was able to resolder the power board seem to fix all didn't really cost me much cheaper thean shipping back to spherex or whoever
Sep 30, 2007 | Spherex Xbox 5.1 Surround Sound System...
Spherex surround sound wont stay on
Mr. Vargas is right mine also won't turn on and upon further inspection I found burn discoloration on the boad where the two power cables are connected. The burn spot is where the four diodes are locaed and the big power cable connection. I am not sure how to replace these diodes or where to find them. Never done this stuff but will try for sure. Please post if you have any suggestions. thanks
Aug 23, 2007 | Spherex Xbox 5.1 Surround Sound System...
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
465 people viewed this question
Top Spherex Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
