Question about Texas Instruments Office Equipment & Supplies
Whenever i press the graph button on my ti-83plus i get an error message....ERR:INVALID DIM
Posted by jstaggs on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Jan 23, 2010
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
Whenever I try to graph something on my TI-84 plus I get the message err: invalid dim
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
Whenever i press the graph button on my ti-83plus i get an error message 'dim' it did not come with in depth directions & i am lost please help!
You caon download a guidebook from http://education.ti.com
Jul 21, 2010 | Texas Instruments TI-83 Plus Calculator
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
Clearing or correcting an error message on the TI-83 Plus
Press [STAT] to open the Statistics editor. From the menu that displays, select PlotsOFF and press [ENTER] twice. The calculator answers "Done".
Open the [Y=] editor to enter the functions to be drawn. Use the Trace ONLY after the graph has been displayed.
To clear any message without necessarily removing the conditions that yield the error press the CLEAR button.
Apr 13, 2010 | Texas Instruments TI-83 Plus Calculator
Not Graphing
If that's not it, post a comment and we'll go from there.
Apr 08, 2010 | Texas Instruments TI-84 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
590 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Scoee Scoffer
Edward Easley
Edward Easley
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
