Nintendo DS Lite Console Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i download file ds menu.dat cheers - Nintendo DS Lite Console
Anonymous
Level 3:
  • Master 644 Answers
  • Posted on Jan 15, 2010
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
217701
Points
1886
Http://r4ds.cn/download/r4_v1.18_kernel.html
Had to format memory card what do i need to run r4 and memorycard
You will need to download and reinstall the R4 firmware.
After downloading and decompressing the new updated files, there will be one shell folder and two files _DS_MENU.DAT, and _DS_MSHL.NDS.Copy these files to the root directory of TF card to replace the former files (ex. F:\ or E:\).
You can download the update files and firmware here:
http://www.r4ds.me/download/r4ds.html
3helpful
Deleted the "ds_menu.dat" how can i get it back
When you mean the DS_MENU.DAT, do you mean the menu on your R4? You can get it back, and I have links, but unfortunately that file has not been updated since April 2008. Here is the link however: http://r4ds.cn/download/118/English-1.18.rar
3helpful
2answers
Couldn't dind ds-menu.dat using R4 card
you can download the files needed for the r4 just google it. You may need to use dslazy or fixit in order for the game to operate. good luck!
Insalling m3 resl deal but cant find DS MENU .dat
apparently m3 dont do upgrades now but this might help http://www.m3-forums.net/viewtopic.php?f=4&t=312
basically it converts the r4 ds menu.dat to work on m3 simply (may work for m3 real) so now all you have to do is go to r4 download site and download latest version. 1.18 from here http://www.r4dscart.com/r4-software.html (select the english update) then patch ur dat file replace it back to where you took it from before patching and then copy all 4 files ( _system_ moonshi _ds_menu.dat _ds_mshl.nds) into the root of micro sd card. advise you to copy any files/games you have on your mem card then copy the games over to your newly installed firmware. oh by the way in the link i provided on how2 patch the ds_menu.dat it might be bit vague on where you put the ds_menu.dat file to patch it, all you do is drag and drop it into the PATCH app thats inside the "r4 to m3 patcher" folder. post a reply to let me know how you got on
9helpful
5answers
Cannot find menu dat file
To format any drive just insert the memory, right click over your memory drive in My PC window, and there should be an option to Format this drive, formatting will erase all the card contents so make a backup in your computer first.
When you click on "format" a window will appear to chose FAT or FAT32 (try FAT32 first then if not working try FAT), dont have to do nothing on the size option, write a label for the drive if you want, not needed, let Quick Format clear, click on start button and you'll see a proccess bar, when it finish it tell you and you have a formatted drive.
Put the sistem files and one rom to test again in the memory, test it on your DS. Be sure you have the right files for your card, the www.R4ds.cn site only supports R4 cards, not R4 III, R4 SDHC or any fake non R4 hardware.
10helpful
5answers
Menu.dat issue
the _DS_MENU.DAT could not be found bcuz you guys probably deleted it or edited it accidentally. if you edited it, put it back to its normal self right away. for example, it was _DS_MENU.DAT.
if you edit it to look like, DS Menu.Dat , your R4 wont work. so fix it to its original self.
: ) pia
109helpful
11answers
hi
first of all , check your r4 version.
there are many.
have you put the right firmware on your r4?
original : http://r4ds.cn/download/r4_v1.18_kernel.html
r4 revolution pro : http://www.r4dspro.com/download_en.html
r4 ultra and de luxe : http://www.r4deluxe.com/en/down.asp
r4 III : http://www.r4dsl.net/download-en.asp
after that it should work.
or maybe you should format your memory card first.
1helpful
5answers
Menu.dat issue with nintendo ds
go to the site www.r4ds.com
then downlaod the latest kernel and after downloading it , copy it and paste it in your TF card folder!
dats it.........u r ds is now gonna run with r4.!
1helpful
Error openx menu dat error
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
9helpful
12answers
Nintendo dslite ncard
I did have Error: Data is not align 16k! when i start up my ds.
What I did was..
All the files you need are at www.neoflash.com.
Your need (MK5) v1.45 which is in the download section.
Some of the nds roms do needed unraring before putting on memory card. They should be in .nds format etc.
The files you need are...
DSYSTEM (Entire Folder And Contents
MK5_2Mbit_test_v5.nds
MK5_PassMe.nds
xmenu.dat
When you have these files THEN you can format by...
Please insert both cards in to the DS and power up, tap the screen to continue as you would for any normal game.
You will then come to the menu "USB Mode" and "Menu Mode"
Instead of selecting one please press and hold the "select button" on the DS then tap "start"
Select "Quick Format"
Once complete restart the DS, you will have to tap the screen as above and this time select" USB MODE"
By formatting the menu file will have been deleted from internal Memory and will need replacing with the files. downloaded from neoflash.com
(MK5) v1.45
MK5_PassMe.nds
xmenu.dat
(Drag and drop these files only)
Now your new system is ready, restart NDS and enjoy
Will fix almost all problems with DS Firecard and applies to both 8 and 16gbit.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
