Sony Playstation 3 (PS3) Console Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have USB verizon modem connected to Belkin router. Works fine for 2 computers on general internet surfing. I keep getting bumped off when I try to play PS3 online. Are my speeds to slow at 60 to 80 kbps or are there any changes I can make to get this to work with MW2.
Anonymous
Level 2:
Sergeant:
  • Expert 185 Answers
  • Posted on Jan 13, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
185
Questions
Helped
34131
Points
555
Your thumb drive dosnt have suficant power to keep the ps3 online. i suggest getting a land line if you wanting to play online. thumb drives just arent sufficant enougant to give out that much internet to a ps3. even witha router
I am trying to set up belkin n600 but my internet connection is a usb from verizon how to do i connect?
Hi
Though Belkin play router has a USB port on it, it would not accept the input via that port there by you can not connected the USB connection from Verizon to the router. You need to switch from USB connection to Ethernet connection on the Verizon modem contacting verizon.
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Unable to connect wirelessly to laptop and PS3
ISP DSL ask your provider is your connection is PPOE or Dynamic and after do this.
Note is PPOE you need to type first your User name and Password
6helpful
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Works with verizon not with com cast
It was working with Verizon. verizon is a DSL company and Comcast is a CABLE company. settings will be different for both the ISPs. Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
1helpful
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Trying to set up a vpn server on windows XP using
Did you already forward port 1723? I guess you have done that. To isolate it, try to bypass the router and setup or establish the VPN session there. If it doesn't work, maybe your ISP doesn't allow port 1723 or it's just the modem.
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
