Try resetting the phone to factory default.
Each station has a ringer volume control. Adjust the ringer volume of each station to suit your needs.
If music is to be part of the system, connect a customer-provided music source to the common equipment music interface jack (phono jack) provided for this purpose. The impedance of this
input is approximately 500W. Use the volume control on the music source to adjust the audio level of the music as required.
With the operating system parameters set to default, the rocker switch volume control on
DigiTech and Impact multiline telephones sets the ringer volume level between off and a
maximum level. You can disable the allow ringer off on a system-wide basis. When you
do this, users can set the ringer volume of their telephones between a minimum and a
maximum level, but can not completely silence it.
To Program: 1. Dial 17. “SYSTEM FEATURES ”
2. Dial 04. “RING OFF XXXXXX”
3. Press A1 to toggle between ringer off allow and not allow.
(LED On = Ringer Off allowed)
—OR—
Dial 1 to allow ringer off. “RING OFF ENABLE”
Dial 2 to not allow ringer off. “RING OFF DISABLE”
4. Dial SS for configuration mode.
5. Press SPEAKER to end.
System Programming 3 – 61
Handset Volume Control On Impact Telephones
Description: Impact telephones have 8 handset volume settings at default. You may increase the
number of volume settings to 13 on an individual station basis.
To Program: 1. Dial 53. “STATION FEATURES”
2. Dial 38. “HANDSET VOLUME”
3. Select station ports (LED on = Feature Assigned):
—Station 10–57: Dial 10–57 or press C10–C57.
4. Dial S for next station feature
—OR—
dialS Sfor configuration mode.
To change setting, repeat procedure and make different selection.
Volume Save INTERCOM
SS 7 VOLSV
Already did. Did not work. It is like the phone has an incoming call, but you can still answer from that station.
