Question about Bunn CWT 15-APS Coffee Maker
Change gaskets on BUNN model CWT15-APS
How do I change the gaskets on BUNN model CWT15-AP? The unit is leaking from the top.
  • Anonymous Jan 13, 2010
    I already know what pot I have. I need to know how to fix it!!!!
    please post relevant answers only. Yes, I can pay $535 for service to replace two gaskets costing less that $3 each, but that is not economically feasible when a new machine is cheaper. I need to know how to replace the gaskets. Any other comment is a waste of time!
Milind Shetti
    Guru:
  • 829 Answers
  • Brews 3.8 to 7.5 gallons (14.4 to 28.4 litres) of perfect coffee per hour.
  • Large 200 oz. (5.9 litres) tank provides back-to-back brewing capacity.
  • Adjusts automatically to varying water pressure.
  • For high lime areas, BrewLOGIC® technology calculates flow rate and adjusts brew time to maintain consistent pot levels.
  • BrewWIZARD® technology incorporates simplified programming with a LCD display.
  • Quickerinstall saves up to 30 minutes. Pot level, cold brew lock-out and tanktemperature set easily from advanced touch pad on front of machine.
  • Electronic diagnostics and built in tank drain make service easier.
  • Ensures coffee brew quality with cold brew lock out capability.
  • Brew into decanters.
  • SplashGard® funnel deflects hot liquids away from the hand.
  • Coffee extraction controlled with pre-infusion or pulse brew and digital temperature control.
  • Automatic warmer shut-off.
Posted on Jan 13, 2010
Testimonial: "I'll give these instructions to the person actually doing the change. Thanks - I'll let you know how it goes."
  • Milind Shetti
    Milind Shetti Jan 13, 2010
    Hi ,
    If its leaking i advise you to get a help from the service center as it can be risky you trying out.
  • Milind Shetti
    Hi
    Try this out and let me know if it works for you.
    Removal and Replacement:
    1. Disconnect the water supply tube from the fill
    basin.
    2. Remove the tank inlet fitting securing the fill
    basin to the tank lid, remove fill basin and tank
    inlet gasket. Set all three parts aside for reassembly.
    3. On brewers with faucet shut-off water supply to
    the brewer and disconnect the inlet and outlet
    water lines to the faucet coil assembly.
    4. Disconnect the black wire on the limit thermostat
    from the tank heater switch. On late model brewers
    also disconnect the blue wire from the limit
    thermostat to the control thermostat.
    5. Disconnect the black wire and the white or red
    wire from the tank heater terminals.
    6. Remove sprayhead and the hex nut securing the
    sprayhead tube to the hood. Set aside for reassembly.
    7. Remove the eight #8-32 nuts securing the tank
    lid to the tank.
    8. Remove the tank lid with limit thermostat,
    sprayhead tube, tank heater, coil assembly and
    control thermostat w/bracket (early models only).
    9 Remove the two hex nuts securing the tank
    heater to the tank lid. Remove tank heater with
    gaskets and discard.
    10. Install new tank heater with gaskets on the tank
    lid and secure with two hex nuts.
    11. Install tank lid with limit thermostat, sprayhead
    tube, tank heater, coil assembly (brewers with
    faucet) and control thermostat with bracket (early
    brewers only) using eight #8-32 hex nut.
    12. Reconnect the inlet and outlet water lines to the
    13. Secure spayhead tube to hood using a hex nut.
    14. Install sprayhead.
    15. Reconnect the wires to the limit thermostat, tank
    heater and control thermostat. See limit thermostat
    and control thermostat sections in this manual
    when reconnecting wires.
    16. Install fill basin, secure with tank inlet fitting and
    gasket. Insert water supply line through grommet
    in fill basin.
    17. Refer to the illustration below when reconnecting
    the tank heater wires.
Water leaking from the top
open up the top and check the trough drain for lime. if it is obstructed, the water will overflow. use a screwdriver and poke it through the drain
Nov 07, 2013 | Bunn CWTF 15-APS Coffee Maker
My Bunn CWT15-APS , PF works well except when i push the start button it only makes a few ounces of coffee. Can you help?
It is possible that the brew volume needs to be set, remove the front panel and you find the instructions to set the brew volume.
Sep 22, 2011 | Bunn CWTF 15-APS Coffee Maker
How do I empty the water resevoir on the Bunn CW15-APS?
Syphon it out from the brew inlet hole in the tank basin, or remove the top panel and the tank basin, then remove the grommet on the pressure stat and turn it over in the sink.
Jan 30, 2011 | Bunn CW 15-APS Coffee Maker
I have a BUNN BT10-B Coffee Maker that started leaking. I believe it it is the gaskets between the top trank and the heater. How do I het these gaskets new?
The seal kit is available free of charge through Customer Service at Bunn. If you will call 800-352-2866 and have the model and date code from the bottom of your brewer and we will be happy to assist you.
Jan 16, 2011 | Bunn BT10B Coffee Maker
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 12, 2010 | Bunn CWTF15-TC
Water is leaking from the left side of the coffee filter holder when it is in brew cycle
sounds like you need to change your group gasket, you can find on line for under $6
Oct 22, 2010 | Bunn CDBCF 15 APS Coffee Maker
Our Bunn model B10B starting leaking done the stainless steel cylinder. I took it apart. The part of the top tray between to two rubber washers had disintegrated. How do I get a new black top water...
The water tray is not available but we do have gaskets that usually will fix the leak. If you will call us at 800-352-2866 with the model and date code and we will be happy to assist you.
Sep 18, 2010 | Bunn BT10B Coffee Maker
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn CWT 15-APS Coffee Maker Logo
360 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
