How can i transfer pictures on my internal memory to my SD card? I have a Kodak Easy Share C433. OR how can I transfer my pictures in a album BACK onto my camera?
it seems that your camera is still on internal memory, if your camera was off when you inserted your sd card, ( it needs to be off when inserting it) it should automatically switch over to the sd card.
I'm not sure with yours, but with mine( I have an older version ) I can go into settings & switch it back & forth from internal memory & sd card.
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
After inserting your memory card into the camera, you should be able to transfer the pictures from the internal memory to the memory card. Choose the option to review your pictures and hit the menu button while reviewing the pictures. Within that menu, there will be an option for memory storage. Choose internal memory. Exit the menu and re-enter it while still in the review mode. This time, select the Copy To menu option to transfer your pictures to the memory card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
The Memory card is defective if u continue to use the same memory card more pictures which u take may spoil so pls try to use a diffrent memory card it will work fine.........
