Question about Epson >>> IM800 DARK GRAY 733 MHZ CPU 128MB HDD WIN XP PRO (IM50004040) PC Desktop
Mosfet check please sir tell me the mosfet check procedure also
Posted by bera_madhu on
dealing_with
    New Friend:
  • 83 Answers
1. Switch your multimeter to the Diode test position.
The following steps are for an N-Channel MOSFET.
Hold the Black lead to the MOSFET's source terminal.
2. Touch the GATE terminal momentarily with the Red lead.
3. Then touch the DRAIN terminal with the Red lead without touching the GATE terminal with your fingers.
The multimeter should show a low reading now. (The MOSFET is now ON)
4. With the RED and BLACK leads still connected to the DRAIN and Source terminals of the MOSFET, now touch the GATE terminal with your finger. The Multimeter should immediately show an open cct. (The MOSFET is now OFF)
This is a very simple way to test a MOSFET.
Posted on Jan 13, 2010
Sir I have a DELL desktop CRT monitor which model no is E772p.It is not working .I opened the monitor and checked. I found that switching mosfet was short in power supply.It was taken out from the...
You will need a service manual to get the correct part number, I tried to cross with my NTE data base no luck, went into ebay site punched in the original numbers came up empty.
May 02, 2012 | Samsung SyncMaster 793MB 17" CRT Monitor
SIR, I have a samsung lcd using mosfet
No,get the same mosfet IC.Mosfet dosen't function like a capacitor,capacitors up a litte voltage it no problems.
Mar 17, 2010 | Samsung SPN4235 42 in. Plasma HDTV
My computer is restarting all the time. How can I check itself?
if its constantly restarting/ you have a reboot trojan/ virus you need to run microsoft onecare scan competely to remove it
Jan 13, 2010 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Benq 737s monitor black screen
BenQ LCDs are known for poor solder connections causing the inverter driver transistors to short.
Result is no backlight.
Monitor Mike
Jan 03, 2009 | BenQ FP737S-D 17" LCD Monitor
ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Nov 06, 2007 | Televison & Video
Computers & Internet Logo
393 people viewed this question
Top Epson Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Rob Hill
Rob Hill
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
