Panasonic PT-AE3000U LCD Projector Logo
Question about Panasonic PT-AE3000U LCD Projector
My panasonic projector pt-ae3000u is not seeing my ps3
My panasonic projector pt-ae3000u is not seeing the HDMI connection to my ps3 which is a new machine. Both machines are new. Do I have to do something before I connect both of them for them to see each other?
Posted by VynnieV on
Anonymous
  • 57 Answers
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Posted on Aug 15, 2010
Is Panasonic projector PT-LB20U compliant with HDCP?
Since the PT-LB20U only has VGA, S-video and composite video inputs, it isn't HDCP compliant. You would need a device with DVI (sometimes), HDMI, or DisplayPort inputs. See page 15 for the connections available on the projector.
Panasonic has the manual for the projector on the product page: http://shop.panasonic.com/support-only/PTLB20U-EC.html . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/PTLB20NTU.PDF .
I wish that I had better news for you.
(the high definition copy protection details require the digital video signal capabilities of the newer inputs. Most digital to analog converters (HDMI to VGA, for example) do not support HDCP.)
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
I'm am new at this forum. Please help. I've
Check first if/that all connections are connected as the should be. That in order go to the menu on your tv. Go to picture and adjust the brightness. K
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI...
if you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
Panasonic 3000u projector overheating
it depends after how long the temperature indication comes
if it comes immediately as soon as the projector comes on[say in 1 min] then the ballast circuit has to be replaced.
if the temperature comes after say 5 mins , it could be that one of the exhaust fans is not moving freely and needs to be replaced!
Projector turn off into two minutes and do not turn on
If the Panasonic Logo comes and then the projectors turns off, the main board of the projector requires replacement!
Panasonic logo comes on for 7-8 seconds then shus off.
This is most likely a fan issue. Remove both covers (there are 2), so that the PCB is exposed. Using compressed air (ideally from a compressor, not from a can), blow all of the dust out of the unit, especially near the fans (there are 4 of them). If this doesn't work, you may have a dead fan. PacParts sells replacements.
2answers
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it...
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mehandi Husain ...
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
