Question about Panasonic Lumix DMC-FX3 Digital Camera
Panasonic DMC-FX33 has operated perfectly for 3 + years. Suddenly, when turning on, camera displays message "Please turn camera off and then on again". Lens cluster 'twitches' but does not extend out. Battery is fully charged; camera has not been dropped, jarred, etc.
    Sergeant:
  • 186 Answers
Hello. If you suspect this is a lens problem ,I agree. I've had good results tapping the camera into the palm of my hand while its trying to open. Also try conecting your transfer cable to the camera and then press the power button, this keeps the viewing screen turned off sending full power to the lens mechanism. Lastly,and I should have mentioned it first,If you have a piece of exposed photo film,cut a small strip and work it in the gaps between the lens barrels to try to remove anything which may be stuck in there
builderdale
Posted on Jan 13, 2010
6ya staff
SOURCE:
Flash is not working
Are you sure you turned it on in the camera settings? Try checking the user manual for information on how to turn on flash:
Panasonic DMC FX33 manual
Feb 11, 2014 | Panasonic DMC-FX33 Silver Digital Camera
Flash not working on DMC fx33
Are you sure you enabled flash through the options? Check the user manual for any setting related to flash before considering having the camera serviced:
Feb 10, 2014 | Panasonic DMC-FX33 Silver Digital Camera
How do I unlock memory card
Have you tried removing the card from the camera then putting it back in? If that doesn't work, try referring to the user manual to see if there's a section about locked memory cards:
Jan 29, 2014 | Panasonic DMC-FX33 Silver Digital Camera
The DMC-FX33 doesn't take pictures except sometimes on iA mode
In most cases, the camera is beyond economic repair. If the camera is a few years old, buying a newer one is a better option. I'm seeing brand name 10 MP models NEW for $60. you might check online auction sites for used ones. I've picked up 5 MP ones for $5.
Jul 02, 2010 | Panasonic Lumix DMC-FX33A Digital Camera
Message saying 'Please turn camera off and then on again' Have charged battery, replaced memory card.
The message appears when force has been applied to the lens. You probably need service.
Jan 01, 2010 | Panasonic DMC-FX33 Silver Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Please turn camera off and on again
Sep 07, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
Lumix DMC-FX33 turns itself off
The message appears when force has been applied to the lens. You will probably need service.
Aug 13, 2009 | Panasonic DMC-FX33 Silver Digital Camera
Camera opens and closes repeatedly and then says please turn camera off and then on again and then does the same thing over again.
you should have dropped your camera down to the floor causing the lens assembly to crack. try tapping the device while the message appears. if it works then you are lucky.else you might have to change your lens assembly which costed 60$ for me in my sony camera
Jul 19, 2009 | Panasonic DMC-FX33 Silver Digital Camera
CAMERA UNIT IS PANASONIC LUMIX DMC-FX33 MENU
It may be that for the type of picture you are taking the mode - dial at the top of the camera is not compatible.
Try a couple of different modes by adjusting the dial to auto, etc.
Apr 22, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Panasonic Lumix  DMC-FX3 Digital Camera Logo
303 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
