Question about Tissot Prc100 T22268631 Watch
I have a new tissot Prc100 T22268631 watch, but i don't know how to adjust the time and date. What will I do?
Posted by edwinvaure on
David Tolond
    President:
  • 2,501 Answers
The usual way to adjust time and date is to screw out (not pull) the winder and rotate it backwards or forwards. The winder will have two "out"positions, one for the date and the other for the time. (the "screw" for the winder is to improve water resistance).
If you have already tried this and it does not work, then go to the Tissot web site "tissot.com", locate your nearest dealer and ask for advice.
Alternatively on the Tissot site find your watch under the heading "sport". To view all the watches in a section move your cursor along the dots, this moves the images along to find the one you want.
Select the PRC100 and details of your watch appear and at the bottom of the menu on the left hand side select "user manuals".
Click on "download" on the right and instructions will appear
Posted on Jan 13, 2010
I bought my Tissot PRC100 choronograph. I'am having proble to set a date that changes at 12 midnight.
Try Googling (tissot)(PRC100)(manual) without parens for instructions..
Mar 02, 2018 | Tissot Watches
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
Jan 30, 2014 | Tissot Watches
The date on my Tissot PRC 100 changes either 1/2 day early or 1/2 day late. How can it be set so that the date changes at 12:00 am?
Your watch is 12 hours out, as it "thinks" that midnight is midday.
The solution is to wind your watch forward 12 hours and then the date will change at midnight.
Jul 14, 2011 | Tissot Prc100 T22268631 Watch
I dont know how to adjust time
You can download a manual or contact Tissot direct at this link:
http://support.tissot.ch/
Best regards
Aug 19, 2010 | Tissot T-Touch T33159851 Wrist Watch
How do I set date on my Tissot PRC 100?
alright pull the crown (thats the knobby thing) to position 2. Then turn clockwise until correct date. Now you should have the correct date.
Jul 27, 2010 | Tissot Prc100 T22268631 Watch
The crow dont pulled out
On some watches the crown screws in to increase water resistance.
Try turning the crown anticlockwise before pulling it out.
Feb 05, 2010 | Tissot Prc100 T22268631 Watch
Battery was replaced by a jeweler. Since that
As the jeweller is not a watchmaker, he/she even did not realise the watch is not working properly. It sounds like your watch is having jammed gear train or the jeweller did not know how to reset the watch. Go to this website: www.tissot.ch
If you will not find solution there, you will have to look for watchmakers help.
Rate me, please.
Jul 29, 2009 | Tissot Prc100 T22268631 Watch
Set time/date How??
Follow this link:
http://www.tissot.ch/index_offer.php?c=eu&l=en
Find and download instructions for your watch. Site is quite complicated, but you will find all the info you need if you've got patience.
Rate me, please.
Mar 14, 2009 | Tissot T33.1.588.71 Wrist Watch
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Tissot Prc100 T22268631 Watch Logo
408 people viewed this question
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
