Question about Sharp AR-5320 Black and White Copier
I have some F2 error
It brings an F2 error so its not photocopying
Posted by idorujohn653 on
Anonymous
    Scholar:
  • 54 Answers
F2 02 Content Toner motor connector disconnected Detail Connection detection signal with toner motor is OFF Cause Connector harness defective Connector disconnected Check and remedy Check toner motor connector for connection. Check connector harness to main PWB for connection. Check harness for broken wire. F2 31 Content Process control trouble (OPC base surface reflection factor is improper) Detail Usually the sensor gain is adjusted so that the output is a certain value, by reading the drum base surface with the image density sensor before starting process control. However, a certain output is not obtained by adjusting the sensor gain. Cause Image density sensor defective Check and remedy Check process control sensor output with SIM44-03. (Do not adjust) If the result is far different from the specified value, it suggests the sensor is defective. Check the sensor and harness. If the deviation is relatively small, check the sensor and drum surface for contamination. F2 32 Content Process control trouble (drum marking sensor defective) Detail Usually the sensor gain is adjusted so that the output is a certain value, by reading the drum base surface with the drum marking sensor before starting process control. However, a certain output is not obtained by adjusting the sensor gain. Cause Drum marking sensor defective Improper connection of harness between PCU PWB and drum marking sensor Drum marking sensor contaminated OPC drum cleaning improper Charging voltage improper Check and remedy Check process control output with SIM44-02. (Do not adjust.) If the result is far different from the specified value, it suggests the sensor is defective. Check the sensor and harness. If the deviation is relatively small, check the sensor and drum surface for contamination. 9 –
Posted on Jan 14, 2010
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 04, 2015 | Sharp MX-M314N Copier
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
How to clear error code f2-04 photocopier SHARP AR-5127
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
Aug 07, 2010 | Canon imageRUNNER 8500 Copier
How do I clear F2 and H4 on Sharp photocopier
F2 means wrong cartridge installed, could be a bad cartridge. H4 is a low fuser temp error. try resetting by pressing "#","interrupt","C","interrupt. then press"1","4","start". then turn off/on and see if it clears. if not you will need a tech.
Nov 12, 2009 | Televison & Video
Sharp AR-5320 Black and White Copier Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
