Question about Krups Food Processors
I've lost the instructions to my variomix 1000 food processor. Where can I download a new set please?
Posted by ellecoop on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: instruction manuel for black & decker food processor FP1445
The manual can be found here
http://www.blackanddeckerappliances.com/dyn/prod/user-guide/70/FP1435%20FP1445.pdf
Posted on Dec 20, 2008
ukvacfan
Ryan S
  • 328 Answers
SOURCE: lost instruction manual
Check out http://www.breville.co.uk/contactus.html
You'll have to email or phone them for a user manual.
Posted on Feb 27, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
Anonymous
  • 50 Answers
SOURCE: Need Instruction Manual for a Hamilton Beach Emmie Food Processor
You can get your manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/HAMILTON%20BEACH/544%20EMMIE-_E
Posted on Sep 24, 2009
Testimonial: "Thank you so much for the info on getting the Emmie food processor manual. I got it, I'm just not able to print it - not sure why. But thanks!"
Anonymous
SOURCE: HOW CAN I RECEIVE A USERS MANUAL FOR THE HAMILTON FOOD PROCESSOR
i need a manual for hamalton beach food processor model 70700
Posted on Dec 28, 2009
UstMy dughter gave me a Little Oscar food processor but it has no instruction manual. Where could I buy one please. Thankyou Gaile Erceg.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link
Jul 31, 2011 | Sunbeam 4816-9 Food Processor
I have lost the manual for my fp370 kenwood food processor
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 15, 2011 | Kenwood FP250 Food Processor
How do I get a food processor booklet or instruction guide?
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader.
A 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Black & Decker FP1445 Food Processor
Lost instruction manual for new combimax 600
Hi Click on http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=ui&s=&seite=&sString=3205|HH|HH04|H|CombiMax&subgrp=CombiMax&grp=HH04%3C|%3E&frmTyp=subgrp
Choose the different country listing such as GB for English.
Dont forget to rate Fixya, thank you.
Apr 12, 2009 | Braun K 600 CombiMax Food Processor
Feb 20, 2009 | Food Processors
Lost manual -The Deni 5 Tray Food Dehydrator-
Hi - You can download the manual by clicking the link underlined in blue below:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Food Processors
Food Processors Logo
94 people viewed this question
Top Krups Food Processors Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Krups Food Processor Expert? Answer questions, earn points and help others
