Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Coffee machine Delonghi Magnifica grinding function not working
The function that grinds beans is nt working and makes a terrible noise
Posted by cla_anderson on
  • Anonymous Mar 21, 2014
    light showing pre ground function staying on and cannot make coffee from beans
Adam Peake
  • 421 Answers
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
  • Kasi Gilbreth
    Kasi Gilbreth Dec 27, 2014
    Is this hard to install? Could we possibly put in the grinding wheels?
I have a Delonghi magnifica s plus and it won't grind the beans and as a fault message saying less coffee
Try less beans and see if it works. If still nada it may be an issue with the motor not working and grinding the beans. If there are motor brushes they may be worn and render the motor inert.
Sep 04, 2017 | DeLonghi Coffee Makers & Espresso Machines
Delonghi problems
Do you have dry coffee in the waist bin? do you have water coming ? I can offer you coffee but I can't give you because I don't have it
Aug 16, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Where can I get my delonghi coffee machine serviced please, I live in Northern Ireland
Kenilworth Electrical Spares and Repairs 253 Harolds Cross Road, Dublin 6w. Ireland email: [email protected] phone: +353 (0)1 4968036
May 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica EAM3400 When using pre-ground coffee I get the message; Grind too fine, turn steam knob. I do, but nothing changes. I pull out the diffuser, clean out the coffee, try again with beans -...
That is the reason the old owners gave it to you . You have to change the circuit board for it and it is as expensive as a new unit plus the labour and shipping .
Oct 30, 2013 | DeLonghi Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Grinding makes a lot of scratch noise and coffee wouldn't drip. The machine says to fill the beans but container is full.
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 27, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My delight magnifica is now grinding too much coffee causing lots of excess falling into machine. How to I adjust the grinding time?
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
Jun 11, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
3,665 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
