Hey i have denon avr-3000 it was working good but now it shows protection error and now it not working just protection!! error is coming on screen please help me out with that problem
Its the main amp in your unit. Depending on the construction the main amp can be an IC (Integrated Circuit) or discrete components. Anyway, the protective relay protects your speakers from being destroyed. When a main amp breaks down it normally outputs DC voltage. DC voltage is not good at all for a speaker.
You need to replace all the defective components in your unit before the unit will be up running again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
On most of the Models in the same or different series, the meaning would remain the same. If you are not satisfied, you could still contact Denon, and it would be the same solution.
My main purpose is to offer you the best possible solution, as per my experience on these Models, but yes, if you feel that there could be more solutions, you are most welcome to ask or search.
Let me know, if any help is needed from me.
Hope i helped you.
its denon avr 3000 not 3300 this site dont have option to use denon avr 3000 that why i put denon 3300 please hepl me from this protection error on my denon avr3000 screen
protection operated
