Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My laptop say i am connected with internet access but it is not; when i check network magic there is a red x through router and laptop; how do i fix this...have unplugged and reset but nothing works; seems to be and everyday problem sick of calling dlink. dlink wbr 1310
Posted by kayla160 on
Prashant M
  • 2,277 Answers
Uninstall the network magic . that software has lot of issues.
You can uninstall the program and try to connect using the windows utility. that is very easy and that works properly.
Is there any computer connected to the router with the cable. If yes then open the router set up page and check the wireless settings of the router.
Click here for more information about the router and network
Posted on Jan 13, 2010
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
HI, HI, I HAVE A WRT54G CISCO ROUTER, AND I WOULD LIKE TO KNOW IF I HAVE TO INSTALL THE NETWORK MAGIC SOFTWARE TO CONNECT TO ROUTER ? , BECAUSE WITHOUT THIS SOFTWARE IS NOT POSSIBLE CONNECT MY NOTEBOOK...
You do not need to install Network Magic.
You need to configure your wireless router and then the wireless card in your notebook with the router's wireless settings.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 26, 2011 | Linksys Wireless-G WRT54G Router
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
I have a laptop that as access to the 2Wire router but cannot access the internet. The three other computers on the network have internet access. I changed the computer name and that did not work. I...
I dont understand "2 wire router" ... do you mean you have two cat 5 cables plugged into your router? You only have a 2 port router?
The name of your computer is of no consequence in this regard. Pleae check the cable before yo go much further.
XP is normally very good at connecting ...
I recommend Network Magic to solve all kinds of network issues, including connectivity, security and sharing. Get free eval copy by searching Network Magic.
Dec 30, 2009 | 2wire (1000-400108-001) Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
Dilnk 655 router conected i can connect through wireless on laptop but the desk top which is wired in from router is saying not conected to internet the network magic program says router is not conected...
try reconneccting the lan cable from your router to your main desktop, take it out for about 5 seconds then put it back in, a light should turn on around the port but check with the on screen details. this should fix it, if not you may need to set up a lan connection through thte network thing
Apr 14, 2009 | 2wire (1000-400108-001) Router
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
151 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
