Question about LeapFrog Little Leaps Grow With Me Learning System
Leapster2 shows low battery but the batteries test
The low battery indicator flashes then the Leapster 2 shuts off. I take out the batteries and test them and all four are solidly charged.
  • Anonymous Jan 13, 2010
    I am using alkaline batteries, but my original question did make it sound like I was using rechargeable batteries.
Anonymous
    New Friend:
  • 30 Answers
Use regular batteries not rechargeable ones
Posted on Jan 13, 2010
When trying to download free starter game I get the messasge that my leapster2 is not connected, that I need to replace batteries or make sure I am using eject (which I have done everytime). How can I make...
When you first time connected your Leapster 2 to your PC using LeapFrog Connect, first of all, the software need to be updated both on the PC and in the console. It will takes times for at least 10-20 mins for it to complete the update. You have to wait until the status show "connected".
Sometimes, it will takes longer. So, what I did before is uninstall the LeapFrog Connect and reinstall it. It works perfect after that. Hope it helps.
BTW, you can get more downloadable games for your Leapster 2 here:
leapster-2.blogspot.com
Jun 28, 2011 | LeapFrog Leapster 2 Learning System
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
Does the leapster2 recharging station fit the leapster
This will only recharge the batteries approx. 300 times! After that it is useless! I had to throw mine out because it would no longer hold the charge. Save your money and just buy regular rechargeable batteries.
but to answer your question, no sorry it wont fit.
good luck!
Jan 29, 2011 | Leapster ®2 Recharging Station
When you press the screen it dosen't work. Batterys are in a good place i don't know what to do is a brand new toy
You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Jan 25, 2011 | Toys
My leapster 2 won't let me write my name in the screen?
6) Restart unit
Jan 15, 2011 | LeapFrog Leapster 2 Learning System
After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
6) Restart unit
Jan 13, 2011 | Leapster 2
The touch screen ain't working
Try to calibarte it:
6) Restart unit
Source:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Dec 26, 2010 | Leapster 2 Handheld Game
Recharger and USB cable for Leapster2
you can buy it at the store you bought the leapster ask the sales lady and show the item that you bought and tell them what you have lost..
Apr 21, 2010 | LeapFrog Leapster 2 Learning System
Leapster2 - turns on but screen dark
at the bottom of the toy,near the headphone jack are brightnest control and contrast conytrol buttons.there u can set brightnest that is good for u.
Nov 27, 2009 | LeapFrog Leapster 2 Learning System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
LeapFrog Little Leaps Grow With Me Learning System Logo
346 people viewed this question
Top LeapFrog Toys Experts
Marvin
Marvin
Lawrence Oravetz
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
