Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it won't drain. I've read some forums and the posts suggest a blockage in the pump filter but it is supposed to be located in the sump hose - not sure how to access it. Can you help?
Posted by c_fox on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
A message saying f05
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Jan 24, 2010 | Hotpoint Aquarius WD63 Front Load...
Fault code F05
If Hotpoint or Creda,
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Control panel flashing F05 ?
F05 denotes pressure switch jammed on full, check pump and draining out.
If still no go, then call an engineer.
Dec 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
321 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
