Question about Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker
How to install 4 way speakers - Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker
Posted by joey_snowboa on
  • David Burbee
    David Burbee May 11, 2010
    Hello! Tell me the make and model of the vehicle and I'll wire the speakers... Guru..................saailer
Chris Briggs
  • 160 Answers
Exactly the same way, you would for a normal speaker.
Four-ways combine a woofer, a mid-range, a tweeter, and a "super tweeter" into one speaker. But it should still only have one positive and one negative.
Posted on Jan 13, 2010
4-8 ohm output
it is load resistance. set the amplifier switch to the resistance ( X amount ohms) to match your speakers. Although running 4 ohm speakers at the 8 ohm setting is louder, it will hurt your amp
most home/semi pro speakers are 8 ohm, while car speakers are 4 ohm. If you are doing a multi speaker pa/intercom install use your formula to calculate total load is 2 8 ohm speakers in parallel are four ohms . express them as fractions and add the denominator ie:8/1 +8/1 = 8/2 or 4/1 or 4. now connect that in series (add the top numbers)with another 2 speakers in parallel and you get back to 8 ohm load. repeat the same process over and over and you can hook up to 32 speakers to the amp without needing the 70 volt tap. hope this helped.
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
How to install 4.1 creative speakers in windows 7
i have a same problem..
i have Creative Inspire M4500 4.1 & after i have installed win 7 only 2 speakers works in every media player but in test it shows & tests 4 speakers..
Can you help me out too ?? :(
Nov 21, 2012 | Audio Players & Recorders
What amplifier do i need to connect 4 speakers to my vizio P50HDTV10A TV
Check the back of your set there are 2 Audio RCA Jacks, You can't do it with an amplifier alone because that won't split the channels to 4. You have to go to a surround sound receiver.
Jul 14, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Boom audio, blown fuse
Fill the air with sound from this Boom!™ Audio Boom Bagger Kit. This complete audio kit provides the latest in Harley-Davidson® audio components. When installed, the increased power of the amplifier provides the speakers with a clean signal, and a custom equalization is available to further optimize the performance of the Boom!™ Audio speaker system.
  • 4-Speaker Ultra Boom!™ Bagger Kit
  • Ensure maximum output of your audio system with the recommended High Output Charging System P/N 29900028
  • Dealer Digital Technician software update is required
  • Dealer installation is recommended
  • Kit includes Boom!™ Audio 6.5" fairing speakers, Boom!™ Audio 4-channel fairing-mounted amplifier, amplifier mount and wiring harness
  • Speakers feature two-year warranty
  • Stop by a participating dealer to interact with a unique audio display that lets you simulate how your bike will sound with Boom!™ Audio upgrades. Contact your local dealer for details
From: http://www.harley-davidson.com/store/boom!-audio-boom-bagger-amp---speaker-kit-pa-08-76000411--1
Jun 11, 2012 | Harley Davidson Motorcycles
I HAVE A PENTIUM 4 CPU NO SOUND
hi! just a tip hope this would help, try to check first the cables comin from the cpu to the speakers. if still doesnt work try to uninstall and re install the audio driver for your computer. hope this would help goodluck!!
Jun 03, 2010 | Audiovox Audio Players & Recorders
The size of the Rodeo Speakers in the back?
Hello ramac1oscar,
There were different sized speakers and different locations depending on the year and model of the Rodeo. Some were 4" speakers installed in the rear roof. Some were 5-1/4" installed in the doors. The '99 Rodeo here has 4" installed in the rear roof. I recommend that you plug the appropriate vehicle information in Crutchfield's "outfit my car" feature or do a search on www.modifiedlife.com.
Hope this helps.
Aug 05, 2009 | Car Audio & Video
Hello, I have a 2000 VW passat with a Monsoon radio system. How do you install a new head unit and speakers while maintaining the factory amp? If this is impossible, Can I use the current speaker wires...
Hello ctr1russo,
While it's not impossible to install a new head unit and speakers and leave the factory amp, it'll be a real bear of an install.
In order to work, the Monsoon amp needs 6v which is provided on the speaker leads. An aftermarket head unit will not provide that. Best to just install a new amp.
You should be able to use the wiring, including the speaker wiring, with no problems.
Check out www.bestkits.com for the appropriate adapters and wiring harness for Monsoon equipped vehicles. Just enter your vehicle info and it should bring up the required adapters and harnesses to make everything work properly.
There are three ways to connect more than one speaker to a single channel: 1) Parallel - both speaker +'s and -'s wired together - load impedance will be halved (2 4-ohm speakers in parallel equal a 2-ohm load). 2) Series - The + of one speaker wired to the - on the other speaker and the remaining + and - going to the channel output - load impedance will be doubled (2 4-ohm speakers wired in series equal an 8-ohm load). 3) Using a crossover - connect the bass speaker (woofer) and the input of a high-pass filter directly to the channel output and the treble (tweeter) speaker to the output side of the filter. In any of these connections, you want to make sure that the load (ohms) your amp "sees" is not less than it is rated for. Most amps will work into a 4-ohm or a 2-ohm load with no problems. Going below 2-ohms is bad, because it will cause the amp to overheat and possible fail. Going above 4-ohms is no problem for the amp, but it won't produce as much power (watts) at the higher impedance and your speakers will not be as loud as they could be.
Hope this helps. If it does, please rate as "FixYa:. Thanks!
Apr 21, 2009 | Car Audio & Video
All five speakers are not working
Which One of the five speakers is not not working? LeftFront RightFront LeftBack RightBack or Center Speaker?
Sep 30, 2008 | JBL 5.1-Channel Home Theater Speaker...
Need to install radio
This maybe due to the fact that all manufactured wiring harnesses installed in the corolla are standard looms, you will probably find that you do not have rear speakers installed, however the wires are located beneath the speaker grill by the parcel shelf. the standard corolla stereo only uses front speakers,but the loom has the ability to connect 4 speakers.most manufacturers always fit 1 standard loom as it is cheaper to install a full loom than make variations for different specs and models.check your stereo to see if it is used with 2 or 4 speakers. regards neil
Aug 02, 2008 | 1998 Toyota Corolla
RS525 5 1/4
The infinity system is unique in that the amplifier for each speaker is built right onto the speaker. You will need to bypass it by looking at the wire colors as they go into the JVC stereo, then finding them at the speaker. My suggestion is to just put 2 new speaker wires in and wire the speakers directly to the radio. You will have to routhe them through the dashboard but it's pretty simple to do. BTW, i know that vehicle well as I used to own one and customized the whole van.
Jan 01, 2008 | Car Audio & Video
Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Steven Wander
Steven Wander
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
