HP Business Inkjet 1100dtn Printer Logo
Posted on Jan 12, 2010
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
430
Points
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl
The error code you are seeing may or may not have to do with the cartridges being refilled.
Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems.
QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source
Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray
I found the above article interesting and genuine.
To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product.
Perhaps you will find the following document helpful:
HP Printers Problem with Printhead Printer Failure Ink System Failure or...
I hope this helps.
I work on behalf of HP.
Epson workforce 1100 flashing lights
please help me to find epson office me 1100 resseter
Hp psc 1100/1200 series All-in-ONE INK JET PRINTER PAPER WONT FEED INTO PRINTER
Try cleaning rollers and everything you can get to on paper path. Use hand wipes, or baby wipes, etc
It sounds like the path needs cleaning.
2answers
Fault code 22:10 hp designjet 500 plus printer
check ur iss (ink supply station) & clean them if problem persists then replaced the iss unit
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
MFC Brother printer will not print when Cayan is empty. Why wil it not print in black and white without it? And which ink is Cayan?
Cyan is the blue color ink, and it won't print when any color is empty so that you don't put air bubbles in the ink lines and ruin the printhead.
I have replaced the cayan cartridge and the indicator light continues to tell me to replace the cartridge
just press to ignore that.. it will work normally, maybe you gotta cartridge with an old chip.
Canon Pro9000 - cayan color - not working
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Cayan ink cartridge empty but now cartridge installed
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
2answers
Printer Problems
Will it still print? Mine has said the same thing many times even after changing ink cartridges. I would just push the stop/exit then It will be ready to go. There should be no problem with printing after that.
k24674
Grand Canyon Tech
Grand Canyon Tech
