Question about Pentax Photography
I have an old Pentax me super and have STUPIDLY lost the lens cover. does anyone know where i can get one from? Thank you so much
Posted by ninaputnis on
Jeffrey Babiuk
    Scholar:
  • 129 Answers
Generic caps can be found at large oufits B&H in New York, Helix camera in Chicago.
I find original caps on Ebay sometimes
Posted on Jan 14, 2010
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
2helpful
I would like to use my Sigma 600 Mirror lense on Nikon M80 digital camara body lense was used on a Pentax Super A camara before can it fit
Sorry, no. If it fit onto a Pentax camera then the lens has a Pentax mount. The Nikon (I assume you mean the D80 digital camera, or perhaps the N80 film camera) has a Nikon mount. Since the Nikon mount has a deeper flange distance than the Pentax mount, there are no adapters available to allow you to fit a Pentax-mount lens onto a Nikon camera.
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
I HAVE AN OLD PENTAX ME SUPER 35MM CAMERA AND HAVE BEEN GIVEN A HANIMEX AUTO ZOOM F/80-200MM LENS BUT NEED AN ADAPTER RING TO FIT BOTH TOGETHER.COULD YOU PLEASE TELL ME WHICH ADAPTER I NEED AND IF POSS...
You don't need an adapter ring, you simply need the correct lens. Like many aftermarket lenses, the Hanimex was made in a number of different versions to fit many different camera mounting systems.
Your camera accepts lenses with a Pentax K bayonet mounting, so the fix is to sell your lens (it's not worth very much though) and buy another which also shouldn't cost very much. You can even get them for free simply by asking on FreeCycle, it's where virtually all of my film camera equipment has come from.
It *might* be possible to get an adapter, but it depends entirely upon which mount the Hanimex currently has (you didn't say, and it's not always obvious just by looking at the lens), and very few can be adapted to a K mount. Those that do will lose automatic aperture coupling, making the lens and camera rather awkward to use, and the coupling will likely cost more than another similar lens in the same zoom range.
4helpful
What does smcp -fa mean
SMCP- means: Super MultiCoated Pentax (a term that refers to the anti-relctive coatings that Pentax has been using on its lenses for years F-means it is a lens designed to cover the larger area required of a lens for Film camera use versus the smaller sensor of the Digital SLRs Pentax also makes. Pentax also makes DA lenses , which will only work with their digital SLRs. A- means it will work in fully automatic mode on cameras that have the ability to set shutter speed and F-stop automatically (most modern Pentaxes) It should also be noted that all DA and FA pentax lenses have a modified version of the original Pentax K lens mount, which replaced their first lens mount, the universal M42 used by so many early film SLR manufacurers- this concluded todays pentax lens history
1helpful
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Lens cover won't fully open
wow, i had the same problem too! try taking out the battery and blowing on it a little. it worked for me. ;]
Pentax ME slr (old hand film wind )
the film might not have been catching onto the wheel it has happend to me befor
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Photography Logo
Top Pentax Photography Experts
Ekse
Are you a Pentax Photography Expert? Answer questions, earn points and help others
