Re: How you open a kenmore he2 washer to fix the drain
If there is a kick plate, why I say this is because Kenmore can be any kind.. So if there is a kick plate there will either be 2 or 3 screws to take off then you will see the pump, if there isn't a kick plate you will have to go through the back of the unit.
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Some how there is debris like socks or something small getting down and blocking your drain plug. take the bottom panel off your machine by removing the 3 (1/4") screws at the very bottom of your washer. once the panel is removed you'll see a 1 1/2" PVC white valve plug. open that by turning it to the left untill open (WARNING ALL THE WATER WILL DRAIN OUT THOUGH THIS PLUG) remove debris and you all set.
it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
