I have a Fuji FinePix A330 camera and when I try
Problem with the Fuji FinePix A330 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Sounds to me like the aperture diaphragm on the lens is stuck in a small opening position. If you detach the lens from the camera and look through it, is the whole opening light or just a small dot in the middle? The diaphragm can stick if it gets a drop of oil on it.
The camera is cannot confirm focus, so it locks up. Try changing the button on the lens to M. Manually focus the lens on something and take a picture. Move the button back to A (autofocus). It should work ok. If not, try moving the switch back and forth several times to clean any corrosion. Try another lens on it to determine if its the camera or the lens.
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees.When the shutter button is pressed the camera will focus and take a white picture which can be deleted.The camera does not flash although flash is set to automatic and photo taken in a dark room.Camera flashes (weakly) with flash set to manual on.Lens is unobstructed and appears to be perfectly normal.Camera was not dropped.Batteries have been changed.
