Question about Sony Class AB 600W Bridgeable 4-Channel Marine Amplifier
I bought a sony marine amp from Boaters world. It came with 1 year warranty I bought 2 year extended warranty. Amp is 10 months old and broken. boaters world is out of bussinees. Who can I return to?
  • 4,234 Answers
Since the unit is less than one year old, Sony should repair it under warranty. Also, check the extended warranty parperwork. Normally the seller does not provide the actual warranty, they contract with a service company. That company should still be around. If you are not successful with Sony, please post the exact problem and model number and we'll try to get you up and running.
Thanks,
Dan
Posted on Jan 13, 2010
6ya staff
SOURCE:
Sony bravia kdl52xbr2 problem
hi,hoping that the cable connections are right(check the cable connections once again)..... Sounds like you may have a problem with the video driver boards? I would call up the store where you bought it and ask for a new set or service on this one.
More than likely this is a bad display (lcd screen) the drivers in the lcd display have some problem...... the tv is just a month old so you are still under the warranty period....... just contact the sony outluet where you purchased or the manufacturer for servicing of tv
Oct 24, 2007 | Sony BRAVIA KDL52XBR2 Television
We bought a 2010 Merc Mariner, two days later, passenger side window got off track or something, as it wouldn't close though the motor was working. Dealer said two "clips" or something broke that held...
You have to replace the broken window regulator
I doubt the dealer did a thing but took your money
You can't just put the so called clips back on, as they
are part of the regulator & are broken
Stay away from dealers
You never let anyone inside your vehicle doors, to do
window regulators or motor repairs & you never let anyone
fabricate brake tubing,their all butchers,you do thoses jobs
yourself
No repair was ever made at the dealer
Aug 26, 2013 | Mercury Mariner Cars & Trucks
The SONY LCD TV is 2 1/2 Years old about 6 months ago I noticed a very light pink 3in vertical line, now after the tv is on for about 30 to 45 min the line is black. does any one have a clue how to fix...
The line or dots on an LCD screen are because of dead pixels and tolerable upto a certain limit as per policy of the manufacturer. But line is not permissible and should be changed in the warranty support. The isssue you are reporting is the vertical line and the the film is to be changed. So if the set is not in warranty it might be a big expense as there is no way to fix it at home.
Thanks
Oct 07, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Blower no cool
Chances are the tech said it was a "capacitor".
That is one of the few (and minor) parts that routinely go bad and would be no suprise with a 17 month old unit. Nearby lightening strikes or power surges can cause them to fail. That is true with all brands.
(the condensor is the entire outdoor unit)
Goodman systems typically come with a 1 year all parts warranty, and a 10 year compressor warranty.
Since your unit is 17 years old the capacitor is not under warranty. (unless you purchased an extended warranty plan of some kind.)
$90 is reasonable compared to the typical going rate for a capacitor replacement and service call.
Aug 25, 2009 | Heating & Cooling
Transistors
If it's only 2 months old, it should be under warranty. Have you tried to get it repaired under warranty?
Any car audio repair shop should be able to repair it.
If you want to repair it yourself, it's possible but you'd need basic test equipment and soldering/desoldering tools.
The following page shows you the basics for amp repair. Your amp is somewhat different than the one shown but the troubleshooting/repair procedure would be similar.
Basic Amp Repair Primer
May 16, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Sony Class AB 600W Bridgeable 4-Channel Marine Amplifier Logo
104 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
