The bulbs are screw fit normally
Neff
fan oven element video.
1, If the fan motor . in the
back of the oven is going round and the temperature light is on (normally
little red light), but there is no heat then you will probably need a new oven
element, these are generally very easy to fit and readily available from our
website these can be tested with a electric meter.
To gain access to the NEFF element .you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element,. if you
look closely at the element .you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the element
is open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your NEFF fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motor
is working you will
see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then
you need To replace the oven fan motor
is a little more
expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timer
into AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO
TUTORIALS
SOURCE: no heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
SOURCE: Fan oven element
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
SOURCE: i have fitted a new element to my creda fan oven
You can expect it to smell for a while, as it is a protective coating on the element.
Run it at a high temp for a few minutes with the door open if possible, this should get rid of the smell.
Hope this helps.
Testimonial: "thank you very much for ur solution to my problem i feel better about turning my oven on now"
