Question about Alesis Sr 16 Stereo Drum Machine
Blank display no functions power ok
Blank display except a line of squares at the top, no functions power ok
Posted by g_barnes854 on
Fred Yearian
  • Alesis Master
  • 5,603 Answers
Not sure what you mean by "power OK",
If you have checked that the logic circuits are getting a clean 5 volts DC THEN the power is OK. This requires an oscilloscope AND a voltmeter.
USUALLY when a display shows characters like that it means the processor hasn't initialized the display. Most common problem is too low power supply that doesn't permit the processor to come out of reset.
Bad filter caps can cause the 5 volts to dip below 4.6 volts which would be minimum to operate. A voltmeter might still register near 5 volts but a scope will show the voltage dips.
Posted on Jan 13, 2010
Roland pad 80 is it normal for the lcd display to show a bar of squares and nothing else when pluged in to power and not pluged into anything else?
The Roland Pad 80 has a contrast control, if it's not correctly adjusted, it could cause it to appear all black or all blank.
If the LCD were bad, it's uncommon for both sections to both go out around the same time, since it uses two seperate 7 segment LCD components. About the only way to cause both to go out at about the same time, would be to get the equipment wet, or let it get way too hot or left sitting out in the sun, long enough to dry up the "liquid" part of "Liquid chrystal display".
Oct 15, 2013 | Music
My line 6 spider 3 75W amp will not show any lights when I turn it on nor make a sound. Only the backlight on the display will turn on and be blank. I have tried the factory reset and it still will not...
Probably the 3.3 volt power that supplies the DSP has failed or is being shorted out. If you are not electronicaally adept, best to take it to a shop for repair.
Jan 02, 2011 | Line 6 Spider Iii 75 Guitar Combo...
The display on my Technics KN1200 keyboards is blank -I have not used it for some time but when I tried it Yesterday the display is blank -All the other Functions works well. please help Thanks Fritz
Check if there is a contrast setting knob or function. Often the contrast setting gets clobbered and then the display will be blank... worst thing if it is internal setting and you can't see the screen to change it... In that case do a factory reset on the unit. Usually this is holding down multiple buttons when turning power on.
Dec 29, 2010 | Music
Top console is not working on Pro 1000 Dual Scratching CD Player
Check controller cable between base and remote. Look for bent pins. If appears ok, you may have an internal loose connection. Try and narrow down if loose section is on base or remote. You could have it resoldered if needed. [email protected]
Apr 21, 2010 | American Audio Dcd Pro 1000 Dual...
Its not the internal fuse or plug fuse, their both ok. Just got no lights and only solid black boxes in the LCD display.
Hi there. Switch Mode Power Supply failure. Probably cooked power MOSFET. Only uses PCB to dissipate heat. POOR design and I told them so. (Line 6)
Thanks
Paul
Jun 28, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
No sound, no lights except lcd screen and only shows black boxes
sounds like something shorted. you probably have a shorted relay and maybe more. depends on when the protection circuit kicked in during the short. the relay being shorted will not allow power to even go to the power supply on/off switch. you can test with a mulitmeter, just be care full, black/groung lead grounded to chasis (a must!!!!!! can use a screw hole to stick the test probe in). then set your meter to read 200 ac volts and touch off on a leg of the switch, etc. look at your readings and see what kind of voltage is rolling thru. you should be getting close to 120 acvolts. carefull!!! if nothing then the problem is before the switch, relay, power resistor, diode, etc. The worst case would be a transformer but i am not to sure line 6 power schemes. the relays are hard to find, you should have part numbers on it, for parts goto mouser.com. you can get almost anything.
Jun 26, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Alesis Sr 16 Stereo Drum Machine Logo
379 people viewed this question
Top Alesis Music Experts
Lawrence Oravetz
Harrie
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
