Question about Siemens SpeedStream Modem (4100) (SS4100)
Hello I have a 4100 B Siemens Speedstream from AT&T. The only 2 lights that come on are the Power Light and Ethernet. I have tried rebooting but do not get any int connection. Do I have a bad modem and can this be fixed or do i just need to purchase a new one? Technical Support says that If I unplug the ethernet plug and the light blinks the modem is bad. Is this correct?
Posted by johnnypy on
Anonymous
    Problem Solver:
  • 11 Answers
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Posted on Jan 14, 2010
Is the siemens speedstream 4100 a 56k modem
A 56K modem is used for dial-up internet.
A dinosuar.
56,000 Kilobits per second
http://www.ehow.com/facts_5625952_56k-modem_.html
The Siemens Speedstream 4100 modem is an Ethernet modem.
(Broadband),
http://www.ehow.com/how_6469391_troubleshoot-siemens-speedstream-4100.html
Regards,
joecoolvette
Jun 10, 2012 | Compaq Computers & Internet
I have a Speedstream 4100. When turning on the modem, it goes through the initial tests (lights,etc.), then the only lights that come on are the power light and the DSL light (steady green). The ethernet...
Your computer is not communicating with the router and modem it needs to reset to factory specs then reboot the computer,modem then router in that order.If this does not work contact your dsl provider for info as to your ip address ,gateway and reset with the provider.
Mar 21, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens; SpeedStream 4100 B Modem,will not connect to DSLinternet
usually the DSL would turn on if DSL connection is established. if you already replaced the modem. then your old modem might already be bad.
Feb 14, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
My external Siemens Speedstream 4100 external
take it to the store to have them look it over they will give you advise on what you should do and where to take it
Feb 10, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
I have only power and ethernet lights on my 4100 B modem. Also, the ethernet light stays lit even when yellow cable is removed! Tech at ISP (AT&T) says the modem is defective. Shouldn't they replace it...
I had a similar problem with my speed stream wireless modem, Etisalat technician attended & replaced with a new modem. It looks to me the problem with Power supply as one of my friend replaced power supply for the modem and the problem resolved but my case, I had to change the modem itself.
Sajid-Abu Dhabi,U.A.E
Jun 03, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
4100 flashing ethernet light
If the internet light is not on that indicates a prob with your ISP, call them up and arrange a service call. I had a similar prob a few weeks ago and they had to replace the drop to the house from the telephone pole.
Sep 02, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstreem 4100 ethernet adsl Modem red power light
Hi frisko.... you will have to Reset your router, there would be a small hole behind the router, you can ***** a pen or pin , for 5 sec, an then check, you may have to reconfigre the router from. 192.168.1.1,
Jul 24, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
can be a deffective modem.. they Bell.ca had replaced mine only 5 times..
Dec 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens SpeedStream Modem (4100) (SS4100) Logo
679 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Lee Hodgson
Lee Hodgson
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
