Does not solve these problems H2? substituted for the other thermistors, but still nothing same error ... The whole problem of the scheme not remove the plug from the power supply and printer cable recorded the error, which now does not solve ... help ??????
Full Reset the m?c...
on the M/c press the this oder
1. Cleal- Exfoce -Clear - Exfoce
than
2. type the "14" than pressthe "Star key"
SOURCE: Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
