SOURCE: SGH-P310
As far as i know, pin codes can be found inside your sim pack. Inside your sim pack you can find the sim card instructions as well as your sim card. Along with it is two sets of codes;
-PIN1 w/ PIN2
-PUK1 &PUK2.
Usually it is written in a small secured paper separated from the instructions of your sim.
And both PIN numbers are usually 1234 (If you didn't changed it)
So what you have to do now is find your sim pack and look for the codes. You shopuld have kept it. But if you haven't changed your PINs yet, try to enter the digits: 1234 as your PIN.
I hope I had help.
Notify me if it works...
For further questions about this, don't hesitate to post it.
Experts are always here to help.........
A rate for this solution will be much appreciated. Thank you!
SOURCE: samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
SOURCE: sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
SOURCE: how to remove viruse from Samsung SGH-P310
* 2767*3855 # FULL RESET
* 2767*2878 # CUST RESET
* 2767*927 # WAP RESET
* 2767*667 # MMS RESET
* 2767*36245 # email RESET
try these codes...
I want drivers for the samsung SGH p310 card phones so that i can download my photos to the computer
