A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
You may also try to update your printer
driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system,
download and execute the file.
Please visit the Lexmark website to download and install the Lexmark X6100 Series Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
1.
Disconnect the printer from your computer.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
