Question about Refrigerators
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the bottom shelf to remove the galss to clean this up?
Anonymous
    New Friend:
Brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Posted on Jan 13, 2010
Testimonial: "Gee... you are really smart! When id doubt brute force is good."
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Howto Clean the glass shelves in my LG refrigerator
Will they go in the dishwasher? If not, use an old toothbrush to get into the edges; use lemon juice or vinegar to degrease, rather than a bleach.
Apr 24, 2014 | LG Refrigerators
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    Model PTB1953GRO Maytag Refrigerator-Water drips into
    you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
    take all out even the ice maker unit
    take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
    Dec 31, 2009 | Refrigerators
    Cracked border to bottom shelf of frigidare refrigerator
    240350614 is the part number for the shelf border that you need...price is around $26
    Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
    Need to clean liquid drip from inside of door whirlpool built-in
    Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
    I am sending you a picture of the door pieces and how they line up inside the frame.
    Please let me know if I can assist you further.
    Vic
    Jul 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
    Liquid dripped into the door and onto the glass, how do I clean it?
    Hi, The door has anywhere from 2 to 4 glass pains. Some models ranges you can just lift the door up and remove it from hinges. There are screws holding seceral layers of frame work. The outer shell should remove first with screws on the bottom edge of the door. With any luck, that is all you will need to remove.
    I hope this helps you.
    Please provide model # and let me know if I can assist you further.
    Vic
    May 27, 2009 | Kitchen Ranges
    How to remove take glass shelf to clean trapped spills
    lift the front nosing by prying with your fingernails up...it will roll in place allowing you to remove the glass
    Dec 20, 2008 | Maytag MTB1895AE Top Freezer Refrigerator
    Refrigerators Logo
    414 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
    john h
