Question about Yamaha Music
No sound from Yamaha Electone HS-6 - Yamaha Music
  • Anonymous Jan 13, 2010
    I have tried the headphone socket and yes i do get sound and the pedal works, checked the onboard fuses and they are both ok too.
    I have removed the speakers individualy and they also work! i am at a loss as to finding the solution.
    many thanks for your tips fredy2
Fred Yearian
  • Yamaha Master
  • 5,603 Answers
First check if you get sound from the headphone jack.
Do you hear anything as the power comes on from the speakers..? A slight bump?
A lot of these dead audio things can be traced to a failure at the expression pedal. often these use a light dependent resistor and the illuminating lamp burns out. This is all down by the pedal.
Many of the Yamaha organs, including the FX20 I have, have circuitry that checks that the power amp has DC balance before a relay closes to connect the speaker. A failure in the amp can cause dead sound as well.
Posted on Jan 12, 2010
  • Fred Yearian Jan 14, 2010
    OK... That sounds like the relay that connects the speakers is not actuating.
    On the FX20 Yamaha, (The HS6 is PROBABLY similar) this relay does the following:
    It disconnects the speakers when headphones are plugged int. Hence, a failure in that switching circuit would disable the speakers.
    It delays for a period determined by an RC timer before closing the relay to connect the speakers.
    It monitors that the power amplifiers are in DC balance before connecting the speakers.
    The key is to get a schematic for the organ. Yamaha USUALLY sells a complete service manual for $15 on CD rom for their instruments through the Yamaha parts people in California. It would be a good investment for you... The parts person usually transfers you to another person who fills the order.
    The amplifiers in most of these organs are in the STK (Hybrid stick) type amplifiers. They are easily damaged so be careful when probing in the area.
    Since the headphones are working OK, I kind of lean toward a failure of the relay timing circuit or a failure of the headphone jack switch.
Anonymous
    New Friend:
  1. try to replace your power amp. stk 4026 11 a new one
Posted on Apr 13, 2010
Hi,is it possible to upgrade the rhythm's and backing on an Electone HS organs/or similar. Thank you Chris
Chris, most likely yes, depending on the actual model. Best to contact Yamaha directly. Here's the link-
Contact Us Support Yamaha United States
Mar 07, 2017 | The Music
I have a Yamaha Electone HS-6 which for some reason won't power on anymore.. is there somewhere I can look at to get it fixed? where should I be looking at fixing this? Fuse? power box maybe?
Yamaha has a service locator at http://usa.yamaha.com/dealers/service_locator/ I ran it and it came up with the exact place local to me I would have taken it to. I know their reputation and have had service done by them before with excellent results. Your organ's a pretty complex unit, so if I were you, I'd take it to a Yamaha recommended facility, after checking with Yelp.
Jan 12, 2015 | Yamaha Music
Organ repair
Yamaha electone organ have no sound el 25 need help thnks...
Sep 03, 2013 | Yamaha Music
HOW TO GATE WIRING DIAGRAM YAMAHA ELECTONE HS-4
Looking for a Service Manual....any suggestions?
Sep 15, 2012 | Yamaha Music
Yamaha Electone HS-4 doesn't remember settings
checked the internet and it states in the manual that if you do not use the organ for long time the user memory will be lost but the factory memeory will not be affected. check the below link:-
http://archive.org/stream/YamahaElectoneHsUsersGuide/YamahaHsUsersGuide_djvu.txt
Aug 30, 2012 | Music
I Have Yamaha Electone HS-4. I already changer a fuse but i have no sound. Someone said, for change a fuse, i must change also a transistor or condensator? Help please. Thanks. [email protected]
the problem is the main output amp. It is an IC so it is better left to a tech to put it in. Just had the same problem with mine. Seems to happen when unit is left on overnight.
Oct 19, 2009 | Yamaha Full-Size Keyboard
Yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Sep 16, 2009 | Boss Micro BR Digital Recorder
Hi, Yamaha Electone HS-4 NO SOUND
j have had the some problem on hs 7 . The relè not work probably you have a cold o breaked joint on power amplify integrate or it is broken.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Music Logo
2,212 people viewed this question
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
