Question about Panasonic Televison & Video
I have copied a personal wedding DVD onto a VHS
DVD to VHS copying.
I have copied a personal wedding DVD onto a VHS tape, but on re-play of the tape the tracking seems to be out or it has not recorded properly, as there are sound or tracking lines at the top off the screen approx 20/25mm deep.The picture is totally unsteady, no amount of re-tracking will rectify it, yet if I record from direct viewing onto a VHS tape or from a digibox likewise the results are excellent. Sorry I omitted to say that the model of the recorder is a Panasonic DVD recorder Model DMR-EZ47VEB.
Many thanks Jim.
Anonymous
I contacted Panasonic direct by phone & they were extremly helpful.
Many thanks ,
Your's, J W Firth
Posted on Jan 15, 2010
Can DVD DISKS BE COPIED FROM VHS TAPES ON A dual; DECK MACHINE?
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
RCA DRC 8310 - not copying from VHS to DVD. When I am playing the VHS tape I press the COPY button, it says that is copying for about 10 seconds and then stops and locks up,. If I press the RECORD...
stay with the 8x dvd (these recorders look and only work with certain types of dvds)...if your manual says maxell stay with it dont look for the brandless sale...use 8x unless your have updated your machine with new firmware from the mfr. for that 16x...are you trying to record HBO / DISNEY? its not going to be allowed on DVD...yes you can record both onto tape...but not digital..(I put all my movies onto dvd, my kids still have tape DISNEY)
hope this help
Mar 10, 2010 | RCA DRC8300N DVD Recorder/VCR
I video taped a wedding and am trying to copy from my camcorder "VHSC" to VHS RECORDER - PROBLEM IS I AM GETTING AUDIO BUT NO VIDEO when i try to replay from vhs tape on VCR
I can only believe that you did not connect everything (the yellow video cable) correctly.
Tape to tape copies are normal and typical. Please consider retrying - and just do a few minutes of test video to confirm that it is working.
If you were doing a digital translation, I could understand a problem - but VHS to VHS should be a straight copy.....
Let us know how the test works. (BTW, I had a bad quality video cable - and had to replace it with another - which worked (and everything would display on my TV but would not copy onto another tape. My expert said that a copy protection thing in the record mode of the VHS recorder was the issue - ONLY a strong signal will be copied.
Oct 14, 2009 | Quasar VM-L153 VHS-C Camcorder
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS to DVD
I just bought at Best Buy the Samsung DVD Recorder & VCR. You can copy your VHS tapes right to DVD and or hook up an external source into the deck and copy them to DVD.  I find it working well but many of my tapes have tracking issues which is becoming a hurdle for myself.
Apr 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
