Question about GPS
Needing a uses manual for a si-tex CVS-209 please
Posted by info31217 on
Anonymous
    President:
  • 1,566 Answers
Try to check from this link out:
http://www.si-tex.com/2009support.htm
There are manuals for GPS devices listed there.
Goodluck.
Posted on Jan 12, 2010
I have a very old Si-tex pro II finder that im trying to get running can any give me a diagrame of how the wiring. the coulors of each wire does what? witch plug/wires runs to the tranducer??? Thanks Sam
Hello, Ticle33 did you ever get he hold of a wiring diagram for the si-tex profish II? I am in the same situation and cannot find one. Hope to hear from you. Thanks /Tom
Si Tex CVS - 106MKII fish
hi guys i need the manual guide for cvs-106mk2 in greek version....
May 04, 2009 • SI-TEX GPS
1helpful
Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
1helpful
I need a manual for Si tex profish II
http://www.si-tex.com/html/support.html
E-mail them at [email protected] with your request and they will e-mail the manual to you.
Need info or a manual
I've found SI-TEX's support page: http://www.si-tex.com/html/support.html where they say this:
Printed copies of retired products and the manuals above are available for $15, if mailed within the United States.
E-mail or call us to request a printed version of a manual.
Their number is: (727) 576-5734
Oct 29, 2008 • Boating
1helpful
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
2answers
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
GPS Logo
Top GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
