Audiovox SIRPNP2 SIRIUS Radio Receiver Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
  • Anonymous Mar 22, 2014
    My radio displays "Antenna not detected". This radio has worked perfectly for 3 years!
John
Level 2:
  • Audiovox Expert 510 Answers
  • Posted on Jan 12, 2010
John
Audiovox Expert
Level 2:
Answers
510
Questions
Helped
193777
Points
885
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Which plug(connection) on bottom of ST5 sirius radio is the antenna plug?? keeps losing the antenna, i have replaced the base with the same error ocuring
The small, gold, circular connector on the bottom of the unit. You can purchase a repair on eBay if the antenna connection has loosened itself from the board.
2answers
Keeps coming up no antenna detected...changed antenna ...same problem
Sounds like it could be the dock itself, but could also be the radio. Do you have other docking stations to test it out in? If it works in one dock but not the other, we know its the dock that needs to be replaced. If it does the same thing in both docks it is probably the antenna connection in the receiver.
It tells me there is no antenna not detected
Antenna not detected could be caused by one of three things: The antenna, the docking station, or the receiver. If you have other equipment to troubleshoot, you can narrow down what is causing your issue and replace it. tss-radio.com is a good source for parts and trouble shooting ;)
Antenna not detected what could this be
Usually the antenna is not plugged-in all the way, or you have broken the little tiny antenna wire. Try another location first, then try another antenna.
1helpful
3answers
SL 10 Antenna not detected
I've had this same thing happen to mine frequently - all I do to solve the problem is to remove the battery for about 20 seconds and then reconnect and power it back on. Always works fine after that (knocking on wood)! Hope this helps!
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
X act sirius streamjockey
any trees or build in the way no signal
2answers
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
No antenna detected
i had the same problem and had to return the antenna to radio shack to get a replacement. the guy said that the antenna had a crack in it from the cold weather or water got into the antenna and that is why it malfunctioned.
Top Audiovox Audio Players & Recorders Experts
John
John
ADMIN Andrew
ADMIN Andrew
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
