Toys Logo
Question about Toysmith Toys
Child overwound? can this be fixed. Took out the mechanical section, but don"t see a solution. when you turn the dial it just makes a clicking sound. If I turn the ballerina the dial does go in reverse and music plays but this doesn't reset it or fix the problem.. Turning the dial manually backward only unscrews it though. Basically can not wind the dial to make her sing/spin.
Posted by kellygirrl on
richie46
    Top Expert:
  • Toysmith Master
  • 12,962 Answers
Not for this forum.
Posted on Aug 31, 2017
5 Related Answers
Kevin Rahme
  • 401 Answers
SOURCE: makes winding in the front end when driving straight or turning right
Hi it needs a hub bearing sounds like the left one
jack up the left side so the left wheel is off the ground and start the vehicle and spin the wheel up to about 30 mph and you should hear the same noise and if not jack up the right side and do the same
hope this helps you
Posted on May 11, 2009
Anonymous
  • 714 Answers
SOURCE: I have a Ballerina Music Box that doesn't spin.
We recommend a clock shop that also works on Cuckoo Clocks.
The music gear box is almost the same.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
Posted on Feb 25, 2010
gggg
  • 904 Answers
SOURCE: Friend threw out the instructions.....mobile has
You should be able to turn the dial freely. Have you tried turning it in both directions? If it won't turn, try hitting the on/off switch to the other position, and see if that makes a difference.
Any luck?
Posted on Oct 24, 2010
Anonymous
  • 129 Answers
SOURCE: I have a samsung Hp s5053 and My TV is making this
Any time you have this issues the power supply needs to be replace. Look for the number on the board it should be the biggest board on the TV. Google it and it very simple to replace.
Thank you
Posted on Nov 01, 2010
Testimonial: "Great info and simiple just like I Like it. Will com to Fixya.com anytime I have a problem"
Fred Yearian
  • 5603 Answers
SOURCE: I just received a GPX JM250S Karaoke Party
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Posted on Dec 27, 2010
1helpful
I want to know if there is a diy tip to fix my vintage ladies "overwound" watch
read this.
http://www.howwatcheswork.com/watch-repair/troubleshooting/overwound.html
My car makes one click noise but it`s not the starter or solenoid
bad battery
bad ground
bad starter relay
dirty battery terminals
2answers
My can makes one click noise but it`s not the starter or solenoid
Strange. Why did the mechanic not find the problem?
How to fix an overwound clock
first thing you will need a new spring
2answers
I have a 2006 LG 42PC3DV Plasma TV and everytime I try and turn it on it makes a double clicking sound and then turn back off..any reason why?
try to test the relay,, or maybe the capcitor, diodes in power source section with your multi tester,, and i think, there is a thermostat beside power that leaks or defective maybe,, then try to change it..
Overwound watch
there is no way to overwind a watch . If your watch crown and stem is stuck and cant turn then one of the wheels are broken or clogged. You will need to take apart the movement of the watch to explore the problem.
It is highly recommended to bring it in to a watchmaker at this point.
Jan 28, 2012 • Watches
When I back out of driveway and turn rear of the car to the right a loud popping noise in the front right wheel area. Took it to a mechanic and they thought it was fixed. Charged me $287. to replace lower...
you don`t say if this is a 4x4 truck.if it is it could be the Ujoints/halfshaft joints on the side thats making the noise.another thing to have checked is the upper and lower control arm bushings for being worn out causing the noise.just suggestions.
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
1helpful
This Le Locle is new, not sure if it was overwound or not but now it has stopped working
Your watch is an automatic type and it should therefore not be possible to overwind it.
Automatic watches thrive on use but if they are unused for mor than 2-3 days they will stop.
The watch should start again if you wave it gently from side to side for a few minutes ( between 100 and 200 times; this operates the self winding mechanism). To maintain operation the watch should be worn daily.
If you haven't got a set of user instructions, go to http://www.tissot.ch/?mod_collections/action_getsubfamilies/colid_0005/famid_0039/refid_T41_1_483_53 and click on "user instructions" to get them.
Top Toysmith Toys Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Toysmith Toy Expert? Answer questions, earn points and help others
