Question about HP (LSI20320C) (LSI20320C-HP) SCSI Controller
Configuring HP LSI Logic SCSI Card
I am using HP-LSI-Logic-Ultra320-SCSI-Controller-PCI-X-403051-001 in Proliant ML-570 G4 server, with an external Ultrium 960 tape drive. The throughput is very slow. Diagnosis shows that card is set to narrow bandwidth. How do I change it to wide mode?
Posted by IT Guy on
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: raid config problem
download a driver over the net
Posted on Mar 11, 2008
micromaster
micromaster
  • 3614 Answers
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
Anonymous
  • 6 Answers
SOURCE: problem with scsi driver proliant ml 370 for NT4
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Posted on Dec 28, 2008
Anonymous
  • 30 Answers
SOURCE: Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Posted on Jul 24, 2009
Burim Hoxha
  • 468 Answers
SOURCE: My HP Proliant ML370 server has no video. Can I
There is standard Integrated ATI Rage XL Video Controller with that server.
Posted on Apr 14, 2010
Windows 2003 OS installation problem on LSI MegaRAID 320 SCSI CARD so how to install windows. pls advise
use floppydrive to select driver / dump server media & drivers into on folder.use windows unattended cdcreator to create media with drivers
Mar 25, 2011 | LSI Logic MegaRaid SCSI320-4X (320x4128t)...
Lsi20320ie does not be recognized by windows server 2008 system in dell R710 server
I guess it's difficult to get free ************ for your office, but you can get a much cheaper one from www.vanskeys.com, I got my key from this site and its low price surprised me a lot. You can go this site to have a try.
Feb 16, 2011 | LSI Logic LSI LSI20320IE storage...
Ths screen displays ERROR,Expansion ROM not initialized-PCI network controller on Motherboard. Bus:04,Device:04,Function:00 how do i fix this? I am trying to install win 2003 server ,system not...
The ProLiant ML110 server with System BIOS Version 16 supports a total of eight IPL devices. Four IPL devices, such as the IDE controller and the floppy controller, are integrated, leaving support for four additional PCI IPL devices (i.e., PCI card plugged into PCI expansion slots); however, the ProLiant ML110 has five PCI expansion slots. Therefore, it is possible to configure the ProLiant ML110 with five PCI IPL devices (such as SCSI controllers or NICs) and exceed the limitation of System BIOS Version 16
The resolution to the problem is to update the System BIOS Version 17 which supports a total of nine IPL devices and five PCI IPL devices. Update the ProLiant ML110 server to System BIOS Version 17
i could not include the url for the download because you did not especify the generation of your server
but follow this link
1.select your server with the corresponding generation
2. select the operating system
3. from the download list select the bios update to a bootable usb or diskete
4.install the os
Oct 27, 2010 | HP ProLiant ML110 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Problem with scsi driver proliant ml 370 for NT4
Dec 26, 2008 | HP Compaq ProLiant ML530 Server
I canĀ“t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Scassy Card for Compaq Proliant ML 330 is defective
You cannot find the details of OEM of this card unless it is written on the card itself.
The card is HP/COMPAQ - SMART ARRAY 532 DUAL CHANNEL ULTRA160 SCSI RAID CONTROLLER CARD WITH 32MB CACHE.
If you want to use a different make card. You can safely go with a adaptec make card.
Cheers - Parveen
Feb 05, 2008 | Computers & Internet
Dazed and confused - unknown system restart
First off, take the message at its word: restart the machine, go into the BIOS and disable all power saving. Also, turn off ACPI if it's on.
Jan 28, 2008 | Computers & Internet
HP (LSI20320C) (LSI20320C-HP) SCSI Controller Logo
476 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
