Is there a reset
The tv is not powering up,it was working a couple of days ago. is there a reset?
Posted by slafavore on
Anonymous
  • 556 Answers
The reset on all tv's is to unplug it for a few minutes then plug it back in.
Posted on Jan 12, 2010
2answers
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
1helpful
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
1helpful
The power went off a couple nights ago now my vizio 32 inch plasma tv wont turn on at all nothing this happened one other time and someone else held down the power button after 3 days and it finally turned...
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
My hp ze4300 will not turn on
Has there been a power surge meanwhile? If so, try unplugging the power cord, press the power button, reconnect power and try booting. Sometimes works.
3helpful
2answers
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Screen does not switch on, mode light flashes orange
Need to remove the Input module circuit box from the bottom of the center and wait for few minutes before putting it back.
This will reset the system from this persistant power off problem.
Best way to prevent it from happening again is to manually switch of the power switch before doing any powering off and on. Most commonly happens during a power failure and power coming back on with the switch in the on position.
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Televison & Video Logo
Top Televison & Video Experts
Ekse
