read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
You don't need a wiring harness for the radio unless you lost the one that came in the box with the radio.
You can find a wiring harness for your car here. Fit My Car That will list all the things that are compatible with your car, including aftermarket wiring harness to connect a stereo.
You don't need the wiring diagram, you need a wiring harness. They are only a few bucks and will save you a ton of time and the risk of frying your entire electrical system. The wiring harness will come with instructions. All radio wires are standardized. All you will need to do is crimp the appropriate colored wire to the matching wire on the harness. Then plug the harness into the vehicle. Hope this helps.
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
