Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
Where can Iget drivers / software to use my RX620
Where can I get drivers / software to use my RX620 ON WINDOWS 7
Anonymous
  • 434 Answers
Windows 7 will install its own driver for your Epson printer. If you have connected the USB cable, disconnect it for now.
With your computer on, power on your printer. Now plug in the USB cable. Win7 will automatically install a driver for your printer.
The Win7 compatible TWAIN driver and Epson Scan Utility software can be download from Epson support:
Epson Stylus Photo RX620 Downloads
Be sure to choose the file(s) for your Win7 version.
Posted on Jan 12, 2010
Anonymous
Sharing my experience to say,if someone need windows product keys,you can go to www.vanskeys.com to got.I'm here to buy a key, a hundred percent genuine.
Posted on May 19, 2016
Can I use my Epson RX630 printer/scanner with windows 7 ?
Yes, the RX630 can be used with Windows 7 (x32 or x64). See http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=stylusrx630&SelOS=Y for the available software. This printer is very similar to the RX620; thus those drivers/utilities may be useful. https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads&platform=OSF_W_7-64 . Use the Control Panel Add a Printer feature if the printer is not identified by the New Hardware Wizard with the USB connection. (First make sure that you have the printer connected directly to the computer's USB ports and that it is in a working port.) If Windows 7 doesn't automatically find the driver for the scanner of the all-in-one, load the appropriate driver for Vista. However, the buttons on the printer may not work to launch the scan to computer applications. If that happens, launch your scans from the computer. Windows 7 comes with Windows Fax and Scan to handle basic scans.
I hope this helps.
(The Epson Event Manager is needed to launch the scans from the all-in-one. It's not listed separately at the first link to Windows drivers/software for the printer given above.)
Jan 06, 2016 | Epson Office Equipment & Supplies
Where can I get drivers for scanner I have downloaded drivers for printer/copier I have windows 8 64bit
At the link below, if you use the pull-down for Win 8 and then expand the "more info" link, you will find that Windows 8 has the drivers for this printer already incorporated. There are procedures listed for loading drivers manually id Windows 8 does not detect and load them automatically.
Epson Stylus Photo RX620 All in One Printer
Jan 14, 2015 | Epson Stylus Photo® RX620 InkJet Printer
Drivers for Epson Photo slylus RX620
To Any & All of you that need a driver for any Epson Printer ( I currently have 2 RX580's -1 with refillables & 1 with a CISS and I have had a CX, a WorkForce, an Artisan & 2 NX's in the past) just go to their website and download the drivers.
Here's the link for the Windows 7 driver page ( you can also get Drivers for Windows XP there) and the Epson Link should detect your Operating System on its own:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=44341&prodoid=54782584&infoType=Downloads&detected=yes&platform=OSF_W_7-64
Just click it & follow the simple directions. Once you get the Driver, then download any utilities that they may have for your All-In-One Printer, like = Easy Print, PrintCD, etc. etc.
NOTE: You should choose the 1st option they give you as it usually is all inclusive and normally is the same thing you would get if you had the original disk in your hand. But after you download it then check the "Utilities" Tab and see if there is any extra's for your particular model.
It should also be noted that for just basic printing, Windows 7 will provide you with a driver for your printer by just going and hooking up the printer to your computer and letting Windows Update find them for you.
Here's How To Do That:
Printer drivers for most models (and not just Epson) are included in the Windows 7 operating system. Follow the instructions below to install the Windows 7 printer and scanner drivers.
  1. Make sure your computer is connected to the Internet.
  2. Connect your Printer to your Computer, Plug in your Printer and turn it on.
  3. Click sw_startbutton_1_er.gif (or go to your Control Panel) and select Devices and Printers.
  4. Select Add a printer.
  5. Select Add a local printer or Add a network, wireless or Bluetooth printer. Mine choice was " Local Printer".
  6. Choose your printer port.
  7. Click Windows Update and wait for the printer list to update. The update may take a few minutes.
  8. Select EPSON as the Manufacturer, then scroll through the list of Printers and select your product. Follow the on-screen instructions to complete the printer driver installation.
  9. Note: Your product may also have an available scanner driver that is built into Windows 7 known as WIA.
For All Versions of: Windows 7 32-bit, Windows 7 64-bit
I hope this helps some of you out as I know it's sometimes hard to hang on to those Disc ( or maybe you got the printer used and it didn't come with one....). If anybody needs any additional help just drop me a line and I'll see what I can do for you.
Brian
[email protected]
(My Experience Level....I built my 1st computer in 1998 with 13 bags of parts and a beige box for $300 and it was a beast back in the day.....) now @ 200 + Builds, plus when I was in College in 1984 I use to write FORTRAN & BASIC programs with a TRS80 that had a real pretty GREEN SCREEN.....lol
I hope this helps
Mar 02, 2014 | Epson RX620 All-In-One InkJet Photo...
I was given the logitech"quickcam" but no software,how can Iget the software?
you can get the driver by asking here:
manualfox.com/driver.htm
They have already found the software.
May 18, 2010 | Logitech QuickCam Connect Webcam
EPSON RX620 PRINTER WILL NOT INSTALL ON NEW WINDOWS 7 COMPUTER
This is where most Pc user fell prey to the new features of Windows 7. I agreed windows 7 is far more secure than any other Operating system that Microsoft has release till now.
But many forget to consider the point of hardware whihc they are going to use in day to day life really support Windows 7.
Only the scanner driver has been release by epson for your printer for windows 7. So there's no work out as they haven't even release drivers for windows vista too.
And you won't find the driver on net as nobody will write the driver program for any printer without the blue print of the printer hardware.
Soory again.
Jan 12, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
I have just installed windows 7 and now my eposn
hello, have you tried updating drivers from epson? if not here is the link for your model all-in-one driver/software page.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&prodoid=54782584&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=22&y=6
if it still doesn't work: do this-
go to device manager and manually install drivers, here is how:
Once logged in computer right click on "my computer" and select "properties", click on "hardware" tab and then click on "device manager" right click on your printer (probably has yellow exclamation mark since it didn't work first installing drievrs) click on update drivers.
now point it to the folder where you saved the drives from the link above.
you might get a warning about compatability but it is okay just click ok/yes to continue.
after its done installing check to you see if you can print.
hope this helps, let me know if need more help.
good luck
reagds,
Amar Sondhi
Dec 06, 2009 | Office Equipment & Supplies
An Epson RX620 Printer cant print from windows 7
I use the Windows XP SP2 drivers with Win 7. Before installing them, right click on the driver file, select properties, select compatibility and the select Win XP SP2.
Lou
Sep 13, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
375 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
