Question about Coffee Makers & Espresso Machines
Our Bunn, Tim Hortons coffee maker was making good coffee, but now, is making weak coffee, despite the fact we are still using the same quantities of coffee and water...
Posted by melody_butch on
  • Anonymous Mar 12, 2014
    Do I have to turn off my Bunn Tim Hortons Velocity Brew at night?
a911slave
    Habit-Forming:
    New Friend:
  • 11 Answers
The little sprinkler in the grounds basket fell off and you probably accidentally threw it out. It splits the hot water stream into three streams. I just emailed bunn and they sent me one for free.
Posted on Feb 03, 2010
How do you clean bunn tim hortons original coffee maker 8 cup
You should be able to get cleaning material in the shop where you bought the machine or in the supermarket, I am sorry I am not familiar with what exactly you can buy inyour neighboorhood. Kolbrun
Sep 16, 2013 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
Nov 26, 2011 | Bunn NHB Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Tim Hortons Bunn Coffee Maker Instructions
which way do the gaskets go together in the reservoir of the tim hortons bunn coffee maker
Jul 13, 2009 | Coffee Makers & Espresso Machines
No instructions
There is a complete instruction manual available on the website. It is www.bunn.com Select @home and then products and select the brewer. Then there is a use and care manual that can be accessed on-line. You can also call customer service and a manual can be mailed out to you at no cost.
Apr 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
970 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
