Vivitar 285HV Flash Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced batteries, fires once, red light stays on. Turn off, restart, same pattern.
bhargav
Level 2:
  • Expert 66 Answers
  • Posted on Mar 04, 2010
 bhargav
Expert
Level 2:
Answers
66
Questions
Helped
22933
Points
125
Finally try with 4 fresh Alkaline by DURACELL.
It will turn green.
If not the capacitor needs to be replaced
Doberman
Level 2:
  • Expert 261 Answers
  • Posted on Jan 18, 2010
Doberman
Expert
Level 2:
Answers
261
Questions
0
Helped
83889
Points
368
Hi Larry,
Change all four batteries, I think one or more were not 1.25 or more voltages.
[email protected]
2answers
Parking lights won't shut off when car is turned off
faulty relay or some wiring issue
..needs fixing will drain the battery flat
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Hi, I am trying to resolve a problem I am having with my Tyan Tempest i5400PW motherboard. My first attempt gave me the following beep sequence : long beep, followed by 3 short beeps, and the same pattern...
Hi.
Try clearing the CMOS by either the CLR_CMOS jumper which should be marked on the motherboard or remove the power cord from the PSU (power supply unit) and then take out the BIOS battery for 20 minutes. Put the battery bac k in and see if the motherboard will fire up and display.
While you wait make sure the CPU's (both of them) are seated properly and also make sure that the RAM is seated properly in the slots.
Good luck.
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
2answers
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
LED light red when plugged in, black screen. Won't turn on
try removing the internal battery from the phone for a couple of minutes then reinsert battery and turn phone on...
Sep 30, 2017 • Cell Phones
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
