Check and repalce the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check its connection wire [flat cables] that connects the T'Con board to panel for any loose contact. Re-seat them once and check. If it do not help you, the T'Con board is likely to be faulty. For more details, check this link. It has details about T'Con faults and respective screen shots. A very useful site indeed.
Make sure the input on the TV is set to hdmi port 2. If it doesn't automatically view on the TV, you have to go into the graphics card adapter settings to set the view to an alternate monitor (your TV). Normally there's also a hotkey command as well (normally one of the F# keys) to switch between displays
Most common proble is Bad Capaciotrs on Power supply Board they will be vented or swollen on Top 1000uf 16v 2200uf 10v 3300uf 10v
Samsung Parts 1-800-627-4368
PTS 1-800-844-7871 this company rebuilts boards
NTSC and Pal are mainly related to Cable/Air reception. Unless you are trying to connect a SCART cable, you can probably just use the video inputs of the TV. Power Supply differences will be the big issue probably.
