Question about Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame
I have a Kodak M820 digital photo frame but my photos will not 'fill the screen' . If I load the pictures onto the frame's internal memory they are fine but if I use a memory card I get black borders either side. Would appreciate any help. Kodak have been no help at all.
Posted by aherne156 on
Julio Hernandez
  • 616 Answers
Simply a format thing, you'll have to adjust your camera to take pics in the correct format, one your photo frame can support.
Posted on Jan 11, 2010
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
How to load photos onto frame
transfer the image from PC to memory card ( JPEG Format) and then insert the card in the photo frame. Then turn on and play.
Oct 05, 2012 | Kodak EasyShare SV811 (8858946) Digital...
I have put a micro card in a kodak easyshare unable to retrieve
Ok, look for a stick of broom or any other thing that is as tiny as a broom, insert it into the card slot and look for a way to bring the card out with it.
Or maybe you should loose the cover of the easyshare m820/m1020 so that it would be easy for you to access the internal part and it would me more easier for you to remove the card.
Take care.
Dec 28, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
I have bought the philips 10.4 inch digital photo frame and im trying to put pictures on it and store them in the internal memory. When i put my card in it starts to install them but then says not enough...
Tough the picture frame states 1000 photos, it really depends on the size of the picture. To resolve this purchase a 2 or 4 gb memory card and download your pictures onto the card. You can insert the card in the slot of the picture frame and then connect to your computer and download your pics from your computer directly onto the memory card.
Dec 14, 2009 | Philips PhotoFrame -10 Digital Picture...
Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
HOW DO I DOWN LOAD PICTURES FROM EASY SHARE PORGRAM TO PICTURE FRAME?
There is no internal memory in your frame. You can transferre them via the SD card onto the frame. But unfortunantly not irectly onto the frame without a SD card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 29, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I can't transfer photos from Adobe to digital frame
The Kodak S510 does not have a built-in internal memory. You can hook it up on your computer using a USB cable with a USB OTG connector and copy the pictures from your computer to the inserted memory card or a USB flash drive in the frame.
Also, make sure that your photos are in JPEG format.
Feb 07, 2009 | Kodak EasyShare One Digital Camera
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
Kodak Easy Share M820
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I highly advise not to forcedly take it out of the frame as it may damage some parts of the frame.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
May 31, 2008 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
241 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
